Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Engine acting funny
    This problem sounds all too familiar, especially coming from an Isuzu... Hot weather, funny Idle and starting issues and surging RPMs. There was a huge problem with Impulses and Storms with the ECM in the late 80's early 90's. Seems the coating GM uses on the Isuzu Boards and circuits to keep out moisture and dust off them expands and contracts a lot with temp. This will weaken some of the surface mount components and cause running problems.
    A lot of the time there would be no codes tripped, or if you had an auto the "code 21" from the transaxle ECU would trip meaning invalid ECM input, which could be the source of the odd TOD light activity mentioned earlier.
    I don't know but last I heard the still used the same basic coating on the boards. There was a small Class action suit threatened by Isuzu owners about the same time Isuzu stopped making cars, but it was met with huge Corporate funded Legal Motions and crushed. Now Isuzu does not even admit there was a problem....
    Any way, its worth checking out. I had a bad one, and every summer it would act up, I would be almost sick of it around end of Aug and then it would clear up again in the winter and drive fine only to return in the beginning of Summer. Oh well hope this helps, just my .02 good luck.
    1999, ASTRAL
    Lightbulb The other items were unrelated...
    ... Got my transmission flushed and diffs serviced, but the engine issue was resolved by replacing the intake gaskets. Not certain what else will cause that problem for you, but I had them clean my injectors as well. I've got 35k miles on my VX and after those services, she is running like new.
    NAVIGATOR
    2001, Proton Yellow, #0580
    My issue went away after a couple of days, just like the last time. It's screwy, though.
    -- John
    Aug 2003
    2001, proton yellow, VX, 1085
    Mine is doing the same thing - but it does not seem to matter what type of weather im in.... I hav'nt been to the site in awhile but jumped on today to see if any of you had similiar problems. Mine is getting bad.... stalls nearly every start, then at times fails several times in a row. I picked up some injector cleaner to add to the gas... suppose I should just take her in for a check up
    Hey TJ...
    If it's that bad it's probably crap stuck in your fuel filter. Go get that changed and it'll prolly clear up.
    -- Best, John
    Aug 2003
    Yup, that did it... got it in and she purrs like a kitten! That was a nice easy fix..... wish they all went so well. Thanks for the help guys!!
  1. Tod acting wierd
    Last Post: 02/14/2017, 12:24 PM
  2. Cruise control/turn signals acting up
    Last Post: 10/07/2010, 08:53 AM
  3. Replies: 1
    Last Post: 06/19/2004, 04:36 AM
  4. A/C acting up?
    By tomcat837 in forum VX Talk...
    Last Post: 06/12/2004, 10:38 AM
  5. Power Locks acting weird
    By migil in forum VX Troubleshooting...
    Last Post: 10/12/2003, 04:06 PM
