The past couple months, I've been working on my rear storage solution and finally dove into the project during my 1 month vacay...
Project Blog & Photo Gallery
Down facing sub box. Pioneer Slimline subwoofer. Flush mount.
Test fit of sub box and unfinished storage box. I still have the lid to mount and some kind of locking mechanism to keep everything in place...
Update: 11/05/2012
Spraying of the adhesive. (Camie 313)
Almost done wrapping.
Done. I will be adding a rubber lining in the inside.
Fully wrapped, just need to get the hinges mounted.
UPDATE 03/25/2013:
I ran the speaker wire out a tight hole in the back bottom and it is sealed from the inside with liquid nails. It is AIR TIGHT!!
Still haven't decided what to do with amplifier. I really want to mount it behind the panel where the bottle jack is located... Just have to figure out how.
I still need to complete the hinge install in the storage box. I found the hinges online, when opened, a spring holds it open at a 75 degree angel and actually floats forward oh so slightly so it makes no contact with the back of the chair. I'll post the pictures when that is done.
I'm just waiting for the acoustic carpet and adhesive to come in the mail, and I can start wrapping. I also wanted to lay down some carpet to the back side of the rear seats, but I can't find a solid frame behind the vinyl to staple it down to...
