Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: Gear Whine, is it normal??
  1. #16
    Mar 2012
    sold
    Quote Originally Posted by rockhavok View Post
    Mine sounds like a pencil sharpener when I slow down, it's not the brakes. Gave up on it. Some day it will be a grind then a sequel or thud. Then I'll know what it has been all along.
    you are not alone
  2. #17
    1999, Ebony Black, VX, 1614
    I had a similar sound when a pinion bearing was in need of replacement.
    and/or if the pinion nut was reused vs. being replaced after being removed once.
  3. #18
    Oct 2012
    00, Dragon Green, 0366
    Pencil sharpener is close to what it sounds like and only when I slow down! At this point it isn't getting worse and nothing is falling off so I am going to call it Normal!
  4. #19
    Mar 2012
    sold
    im assuming the whining is the tod doing its thing and mine does it much less if i have all 4 tires EXACTLY the same psi, but i also get a bit of a grab and a slight clunk when coming to a stop, then a drop when i let off the brakes - im assuming its something binding inside the diff or brake systems doing something weird, but depending on how i drive it gets worse and better all the time - ive found threads in the archives of people buying their vx's brand new and having the same experiences so im not so sure it couldnt be an engineering flaw, but either way im not really worried about it
  5. #20
    Wrench
    Quote Originally Posted by Maddawg View Post
    Mine makes a whining sound (more like a deep sigh) when I am slowing to a stop. I have given up some years ago worrying about this kind of stuff. It will break and then I'll know what it was, lol.
    Quote Originally Posted by boelt63A View Post
    Same-same...unless something is REALLY making a heck of a racket, it'll either be OK, or eventually fall off...
    As long as you're up on your lube schedule, & that includes front bearing & drive line/steering/suspension component grease, most everything will be all right.
    (my tie rods, sway bar bushings, & lower links are all greaseable)
  6. #21
    May 2012
    2001 Iron Man,Vehicross,0814
    Damn, you're good at this guilt trip stuff. Now I gotta go get under the VX and grease it. Been four years since.
  7. #22
    LOL...I'm a rank amateur.
    Had an aunt that turned pro when she opened her own guilt trip travel agency...
  8. #23
    Oct 2012
    The whine all but went away with new tires. The front two were a whole lot more worn than the back two and that must have thrown something off.
  1. Is this normal
    By bssage in forum VX Talk...
    Last Post: 08/14/2012, 06:55 AM
  2. Is this normal?
    By ibmx2 in forum VX Talk...
    Last Post: 09/23/2010, 08:26 AM
  3. is this normal??
    Last Post: 02/19/2007, 10:27 AM
  4. Is this normal?
    By Mikeys00vx in forum VX Troubleshooting...
    Last Post: 11/20/2005, 08:58 PM
  5. Differential whine
    By PBR in forum VX Troubleshooting...
    Last Post: 05/28/2003, 05:50 AM
