Help. I'm having an issue with my rear brakes that I've not seen posted. My ABS light has been on now for about a year. At first this was not a problem or so I thought. Brakes acting normal but new pads were needed so I replaced them all around. About two months later my daughter was driving it to school across the state, and called to say she was having brake problems. Mechanic at her location said that the brakes were shot. He installed new calipers and rotors on rear and pads all around. About one month later daughter reports intermittent noise and a mechanic in her area sees no problem with her brakes. One month later and the daughter is home and still having intermittent problems. I check brakes to find inner pad on right rear completely worn out and rotor worn. When I tried to push the caliper piston back in it was very stiff. At first it moved ok but then stiffened up as if the return line was plugged. Is it likely that my abs system (with the fuse out) is valving off the return brake line? Does the abs module referred to in previous post include the valving or is it just the electrical part? Any other suggestions to fix this not so intermittent problem now?
