Just filled up transmission, about 8 quarts in, closed fill hole, started unit and atleast a quart came outta drivers side radiator, far away from the lines I just drained/flushed; can't see leak from above, must be another connection thats come loose or do intercoolers outright give out? I suspected this is what may have happened in the first place
