Results 1 to 15 of 96
Thread: Transmission Shifting issue: need help please
    Jun 2005
    2001 Black VX
    thanks Evillecutter-
    Mine is quite a bit more pronounced than that, but it sounds like its in the same ballpark.
    I just end up being in the lower gear, unable to shift up correctly- the engine revs to try to make the car faster and will continue into the red if I would let it.
    Aug 2012
    99 black vehicross 1233
    Mine just started doing the exact same thing....at about 105k miles. Has anyone with this problem ever taken it to a mechanic and diagnosed the problem?
    Jun 2005
    2001 Black VX
    Quote Originally Posted by Home_Sauce View Post
    Home_sauce,
    Check out this thread, as it MAY resolve your issue
    http://www.vehicross.info/forums/sho...elector+switch
    Aug 2012
    Quote Originally Posted by creeg View Post
    Home_sauce,
    Did it solve the issue for you? Thanks for the link, I will try and do it this weekend. Seems like something I can handle with my limited mechanical skills....
    Jun 2005
    2001 Black VX
    Update:
    The mechanic thinks its a stuck valve in the transmission. They were driving it with a diagnostic plugged in, and were finally able to reproduce the issue (they were having a hard time reproducing it previously).
    So they are going to add some cleaning fluid to the transmission, I will drive it for a couple weeks, and then they will flush it out.
    Hopefully this works!
  1. Transmission/transfer case issue
    By Kuehjo in forum VX Troubleshooting...
    Last Post: 06/03/2017, 12:08 PM
  2. Transmission issue
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 11/02/2014, 12:05 PM
  3. Transmission Jerks when shifting
    By Vaso in forum VX Troubleshooting...
    Last Post: 10/06/2014, 03:59 PM
  4. Transmission Torque Converter Clutch Solenoid Issue
    By VehiGator in forum VX Troubleshooting...
    Last Post: 07/14/2006, 10:53 PM
  5. Shifting Out of Park
    By shoota77 in forum VX Talk...
    Last Post: 10/13/2004, 11:04 AM
