I know you said you replaced the Model Selector Switch, but were all of the pins in the electrical connector clean/straight/etc? There's also a connector in the same general area of the one I suggested last time that you could check. It's a blue one and is straight to the left among a few other connectors, and it serves as a connection between the A/T Shift Indicator Control Unit and the Meter Assembly
Those two connectors would be about the last common denominators as far as electrical connections go before you have to start looking at the solid state A/T Shift Indicator Control Unit and the Meter Assembly in the dash that actually contains the indicator bulbs.
