Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 96
Thread: Transmission Shifting issue: need help please
    '01 Ebony #0939
    Nice! Glad to hear a success story for a change. Seems like it's been awhile for some reason.
    So replacing the solenoids also took care of the malfunctioning indicator lights on the dash?
    And you're welcome, even though my suggestions turned out to just be a little of this and a little of that .
    Jun 2005
    2001 Black VX
    I still have the dash issues:
    The ABS light is on, and the "D" light does not come on. But it seems they are unrelated items and I need to take care of them separately.
    '01 Ebony #0939
    Quote Originally Posted by creeg View Post
    Ok, new development in the ongoing saga of my stupid transmission:
    The other day, I started up my VX, and was shifting into drive. I went a little too far and accidentally put it into 3, realized what I did, and then shifted into D. The thing is, I had already started giving it gas as I was shifting, so I think it did something weird. I didnt notice anything strange, but when I looked at the instrument panel, the D light was not lit.
    I drove it for a bit, then stopped and turned off the car. I restarted, shifted into all gears while stopped, and checked the dash lights. All shift lights come on when appropriate, except for D.
    I have driven it a couple times since then, and the D light still will not come back on.
    Does this give anyone any ideas as to what I need to have replaced next in my quest to fix this issue?
    Since all the other indicator lights on the dash work ok, I would still have to go back to the wiring/connector associated with the Mode Selector Switch for the "D" not illuminating on the dash.
    It could be something as simple as corrosion on the electrical connector for the switch (although even though the switch has been replaced with a "new" one, that doesn't necessarily rule out the switch itself as having an issue), and it appears as if it would either be the Pink or the Blue/Black wire specifically in the connector. Maybe just disconnecting, cleaning, and reconnecting would be worth a try?
    Oct 2006
    01 Green Dragon 00291
    I had an issue with the shifter lights on the dash displaying incorrectly. Turned out to be a module/box of sorts, under the steering column that had come uncoupled from the bracket that secures it to the firewall. It was dangling by it's wire harness. After placing it back on the bracket and reseating the harness plug, I have yet to have anymore problems with it.
    Jan 2013
    2001,custom,#0947
    IM SO GLAD i found this. the exact same story is happening with me. im going to start with those A and B solenoids and work down from their. i love this site. thanks creeg for the info and process
    ITS F****ING FIXED!!!!
    WOHOOO!!!!
    I am so F****ING happy right now. My transmission issues are GONE!
    I have been driving it for a day now after the repair, and have had no missed shifts, and no thunking on deceleration.
    I replaced the A, B and Band Apply Solenoids, and that seems to have fixed everything.
    I am so relieved that this is no longer an issue. This was the last attempt; if I didnt figure it out with this fix, I was going to sell it. Now I can keep driving it. Whew!
    Thanks to everyone who helped me narrow it down, especially MSHardeman and Y33TREKker and super-special thanks to VXobsession!!!
    You guys have no idea what a relief this!
    Thanks again!
    Craig
    Putting my shopping list together to do this on the Proton. I've been getting the bad shift as well for a couple of weeks (not very consistently yet - just once or twice a day).
    Looks like total bill for the job will be less than $200 (all 5 solenoids, both pan gaskets, filter, fluid).
    I'll try to take pix & write the How2 in case anyone else needs to follow suit.
    Jun 2007
    2001, Proton
    Hell of a deal
    Carter Pewterschmidt
    Apr 2014
    2001, yellow, vx,0838
    Just to let you know, my D light was out after I lifted the vx. I messed with the linkage and it came back on. You might want to check there. Glad to see this fixed. Great work people...
    That others may Live
    Warrior Automotive
    Jake
    Hell of a deal
    I found a kit that has 4 out of the 5 solenoids for $129. http://www.electricaladvantage.net/4...lenoidkit.aspx.
    The EPC solenoid is sold seperate for $41.65. http://www.electricaladvantage.net/4...fits4180e.aspx
    The pan gasket is $3.61 and the overdrive adapter pan gasket is $2.12 from http://www.transmissionpartsusa.com/...ts_s/11031.htm
    The transmission filter is $6.23 from http://www.transmissionpartsusa.com/...rs_s/21012.htm
    I spoke with VXobsession's husban Marcus. He indicated that it's a fairly simple job that I could do myself. He echoed what creeg had earlier said that probably only the 3 solenoids needed to be replaced but if I'm pulling the pan anyway, may as well do them all.
    So reworking my math indicates that I'll end up spending a little over $200 to get'r done (mebbe $220-230 after picking up the tranny fluid)
    '01 Ebony #0939
    Kind of wondering if a simple fluid and filter change would solve some of these problems. How long has it been that these items have been changed on the vehicles exhibiting these shifting issues?
    Oct 2009
    2001, Proton, 0617
    same here, are the solenoids more or less expensive than the mode selector switch?
    Jun 2005
    2001 Black VX
    the solenoids are pretty cheap, but the install is the hard part. I would say the Mode switch is cheaper. Im not sure why that is relevant though: either the solenoids need to be replaced or the mode switch needs to be replaced if you are having the issue.
    I replace my mode select switch when I was having this problem, and it didnt help. It turned out to be the solenoids in my instance.
    Jan 2013
    2001,custom,#0947
    ouch.... so i thought is put it in the shop today.. but i took the vehicross out for a long stroll this weekend.... high speeds it was working great.. still does.. but as son as the tranny heats up, more in california stop and go traffic, it just diez... itle hit 20mph and it the rpms go higher tan 2000 it just spins and acts like its in neutral. after that t has to cool down for it to go back into gear. FML......
    im getting the tranny fluid changed tom, bought the solenoids and the mode switch JIC. i hope this solves the issue bufor i need a new tranny. wish me luck
    Jun 2005
    2001 Black VX
    44ficus44:
    Does it pop into neutral, or does it miss a shift, stay in a lower gear (when it should have shifted to a higher one), and still have power to the wheels?
    If its popping into neutral, that may be the trans mode switch, Im not sure if that is the solenoids. Someone with more knowledge than me on this, please chime in....
    Jan 2013
    2001,custom,#0947
    well im getting the tranny fluid replaced. hoses cheked and all the solenoids/ mode switched. it works fine till it hits traffic. then it just stays in the lower 2 gears till it decides not to even go hajaha. gears are good it just decides to go newtral. itle be back friday roaring im sure.
  1. Transmission/transfer case issue
    By Kuehjo in forum VX Troubleshooting...
    Last Post: 06/03/2017, 12:08 PM
  2. Transmission issue
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 11/02/2014, 12:05 PM
  3. Transmission Jerks when shifting
    By Vaso in forum VX Troubleshooting...
    Last Post: 10/06/2014, 03:59 PM
  4. Transmission Torque Converter Clutch Solenoid Issue
    By VehiGator in forum VX Troubleshooting...
    Last Post: 07/14/2006, 10:53 PM
  5. Shifting Out of Park
    Last Post: 10/13/2004, 11:04 AM
