Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 96
Thread: Transmission Shifting issue: need help please
    Jun 2005
    2001 Black VX
    not fixed yet
    Argh!
    Not fixed yet.
    So I replaced the mode selector switch, and its still missing a shift.
    The only thing that I can think of is that I have the aftermarket offroad plates under the car, and its not letting enough heat dissipate from the area. Since the exhaust is pretty close to the transmission, it may be throwing too much heat at the trans.
    If that is not the issue, my only option may be to have them start replacing solenoids in the transmission as one of them may have gone bad (according to the transmission shop).
    Anybody have any suggestions?
    Also, anyone know which solenoid controls the shift that happens around 27 MPH?
    Frustrated.
    Mar 2012
    sold
    i believe this trans should never have been put in this vehicle - or any vehicle for that matter
    Jun 2005
    2001 Black VX
    Thanks Y33TREKker, I will turn on the power mode on the way home tonight, and see what happens.
    More to come.
    Jun 2005
    2001 Black VX
    Still getting the missed shift in power mode.
    '01 Ebony #0939
    Did your current mechanics have any other suggestions for where you might be able to go to get an actual diagnostic code for the "Check Trans" light you're getting when this happens?
    I know you said they had a diagnostic hooked up while driving earlier in the thread, but it seems that actually having a specific code to work with would be the next best logical step to take as opposed to just starting to throw parts at the problem.
    Jun 2005
    2001 Black VX
    Thanks Y33TREKker-
    I have had the codes checked out with 2 different code readers at 2 different shops. The first shop was unable to get a reading off it, so I took it to a different shop (at the recommendation of the first shop) and they were able to get a code, but it was a non-descript code (Im still looking to see if I have that code written down somewhere) that was not much help.
    Jun 2005
    2001 Black VX
    Ok, new development in the ongoing saga of my stupid transmission:
    The other day, I started up my VX, and was shifting into drive. I went a little too far and accidentally put it into 3, realized what I did, and then shifted into D. The thing is, I had already started giving it gas as I was shifting, so I think it did something weird. I didnt notice anything strange, but when I looked at the instrument panel, the D light was not lit.
    I drove it for a bit, then stopped and turned off the car. I restarted, shifted into all gears while stopped, and checked the dash lights. All shift lights come on when appropriate, except for D.
    I have driven it a couple times since then, and the D light still will not come back on.
    Does this give anyone any ideas as to what I need to have replaced next in my quest to fix this issue?
    As a recap (to those that have not been following:
    I have an intermittent missed shift at 27/28 MPH. It wont shift into the next highest gear somethings.
    I have tried to get error codes, but it doesnt throw any.
    I have replaced the Mode Selector Switch with a new one. That did not fix the problem.
    shifting from 3 to D whilst moving shouldn't cause any damage. Tranny's are made to be able to do that.
    2000, Ebony, VX, 0370
    Thanked: 12
    Maybe it's just a horrible coincidence and your Drive indicator bulb decided to burn out at just the right (wrong) time.
    If you're driving it then it is obviously in gear. Have you gotten it up to highway speed to see if it drops into overdrive? Other than pulling the instrument cluster to see if the Drive bulb is burned out, I would think highway speed would be the only way to see if it is getting/can get out of third gear.
    '01 Ebony #0939
    Under the drivers side of the dash to the left of where your brake pedal hinges there's a small cluster of what looks to be from three to five electrical connectors.
    The very top connector on the left only has one wire in it.
    The vertically-aligned rectangular-shaped connector to the right of the other connectors is for the Automatic Trans Shift Indicator Control Unit.
    You might try unplugging that connector on the right and plugging it back in just to make sure it's seated properly. Given it's location, maybe it got hit by your foot at some point and something happened? And if you're going to check it out anyway, no harm in giving it a good once over just to make sure all the wires going into it are seated properly too.
    Wouldn't be the first time an electrical gremlin issue has been solved on one of these VX's by just re-seating a connector anyway.
    Jun 2005
    2001 Black VX
    Thanks Y33TREKker-
    I checked, and reseated that plug. No gremlins present, still have an unlit D light.
    Jun 2005
    2001 Black VX
    Are there any other cars that have this transmission? Its a GM tranny, wouldnt they put it in anything else?
    Thanked: 12
    This is what the Wikipedia says:
    http://en.wikipedia.org/wiki/GM_4L30-E_transmission
    Nov 2012
    That wiki is interesting. I didn't realize the Rodeos used the same trans. That mean there should be a lot more junk yard parts than I would have thought. Not that it matters for me. Hehe
    There's no 'I' in denial.
    '01 Ebony #0939
    I know you said you replaced the Model Selector Switch, but were all of the pins in the electrical connector clean/straight/etc? There's also a connector in the same general area of the one I suggested last time that you could check. It's a blue one and is straight to the left among a few other connectors, and it serves as a connection between the A/T Shift Indicator Control Unit and the Meter Assembly
    Those two connectors would be about the last common denominators as far as electrical connections go before you have to start looking at the solid state A/T Shift Indicator Control Unit and the Meter Assembly in the dash that actually contains the indicator bulbs.
  1. Transmission/transfer case issue
    By Kuehjo in forum VX Troubleshooting...
    Last Post: 06/03/2017, 11:08 AM
  2. Transmission issue
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 11/02/2014, 11:05 AM
  3. Transmission Jerks when shifting
    By Vaso in forum VX Troubleshooting...
    Last Post: 10/06/2014, 02:59 PM
  4. Transmission Torque Converter Clutch Solenoid Issue
    By VehiGator in forum VX Troubleshooting...
    Last Post: 07/14/2006, 09:53 PM
  5. Shifting Out of Park
    Last Post: 10/13/2004, 10:04 AM
