Results 1 to 3 of 3
Thread: Pre-98 3.2 Transplant
    Sep 2012
    Still looking...
    Hi Everyone,
    I'm looking at purchaing a VX with a blown motor. I've tracked down (2) motors:
    2003 Isuzu Rodeo 3.2 w/80,000 Miles
    This should work without too much effort, but it isn't cheap.
    1995 Honda Passport (Isuzu Rodeo) 3.2 (DOHC) w/27,000
    From my research, this motor will bolt up, but the wiring will be a mess. Is there any reason why the 3.5's bottom-end couldn't be replaced with the 3.2's bottom-end? Maybe I could even use the heads from the 3.2?
    This engine is way cheaper than the 2003. Anyone ever swap a pre-98 3.2 into their Vehicross? Should I run the other way?
    Thanks in advance!
    Eric
    Sep 2010
    2001 kaizer vx
    For one of my transplants I was using 98 Rodeo 3.2v6 - bolts right on. Used same wiring and coils from VX. I am not sure about 95 rodeo.
    Sep 2010
    2001 kaizer vx
    got 2001 rodeo on the hoist - pulling engine out of it. - engine looks the same. throttle bodyon 2001&up is electronic, so would have to utilize one from VX - driven by cable.
  1. Engine transplant
    By Trudy Carp in forum VX Troubleshooting...
    Last Post: 12/20/2011, 12:15 PM
