Results 1 to 15 of 54
Thread: FYI for those people with overheating issues with their VX
Threaded View
  1. #2
    I find it really interesting SO MANY of us are now having O/H problems....maybe it's just time for certain age parts to die...
    My recent experience with new RD radiator in heat in Moab:
    http://www.vehicross.info/showpost.p...6&postcount=16
    On trip to Vegas last week for the photo shoot, my temp gauge was all over the place...so frustrating....
    • Air temp consistently 95-100.
    • Consistently going 65-75mph...so plenty of air flow!
    • Temp climbed going up big hills with A/C on.
    • Temp went down some with A/C off, but took quite a while to return to normal, even when going DOWNhill.
    • Sometimes I had to turn heater on...that was pleasant..., but it lowered it.
    • Fluid was low, added 1/3 gallon 50/50 on return trip. - Seemed to reduce frequency, but not always.
    • When slow or not moving, temp went way up. Going super slow around a block in Vegas with those crazy mobs, it skyrocketed and I pulled off into a hotel drive.
    • Twice it pegged on the white bar on H.
    • Twice pulled off to shut her down for a little while. Helped very little, would start to rise within minutes.
    • It clearly acted INCONSISTENT...would rise when just going on flat straight-away at 70-75.
    • Made it home OK, talked with mechanic next day.
    • Doesn't think it's thermostat since that's most likely to be a CONSISTENT problem...when mechanical thermostat goes, it's gone...wouldn't expect inconsistencies.
    • Spun fan with engine cold, seems somewhat restricted, but I'm not sure.
    • Decided to replace fan clutch.
    • Merlin advised there's been a redesign and you now HAVE to buy the new style fan clutch (~$250....OUCH ) AND a new fan blade (~$100....OUCH again)...
    • Arrived today, will get installed next week.
    • Fingers crossed....
    • Even with all this, I have NO regrets getting custom build...it's way cool, and it will give me more opportunity to have A/C on in hot weather (which is uber important to me...it's an MS thang)....we just gotta figger out what's not workin' right!
    • Repeat warning Bill gave me: NEVER use any coolant additives such as Purple Ice in this radiator..will eventually erode and leak.
    Detailed specs on my Ron Davis radiator-
    • Has more cooling capacity than OEM
    • No plastic parts, all aluminum
    • RD Part number 1-24RO9397
    • Can call Bill Williamson at RD and order it with that number. He's SUPER helpful and explains everything in great detail.
    • About $600.
    • Bill Williamson
      Ron Davis Racing Products, Inc.
      7334 North 108th Avenue
      Glendale, AZ. 85307
      Tel- 623-877-5000 Ext.16
      Fax- 623-877-5001
    • http://www.vehicross.info/showpost.p...72&postcount=5
    MORE specs on my RD radiator:
    Thread on aluminum radiator build:
  1. Overheating issues
    Last Post: 12/06/2015, 03:53 PM
  2. overheating already
    By angeno in forum VX Talk...
    Last Post: 05/15/2014, 08:42 AM
  3. overheating is back
    Last Post: 08/22/2012, 11:52 AM
  4. help overheating
    Last Post: 09/03/2010, 10:32 AM
  5. Overheating
    By bobmumgaard in forum VX Troubleshooting...
    Last Post: 06/27/2007, 12:51 PM
