Results 1 to 6 of 6
Thread: wheel buffing
    Jul 2012
    2000 Dragon (lilasskckr)
    wheel buffing
    Those wheel buffers seem both overpriced for what they are. And look like they would not have a very long life.
    It occurred to me just to stick a micro fiber rag directly in the drill Collete and tighten. I did and it works. But not for long. The rag pulls free after a few minutes of buffing.
    Does anyone know of an attachment that could grab the rag at the end of a cordless drill?
    Rags are cheap. Those buffing balls, cones, ect are like 20 bucks a shot.
    May 2010
    1999 Ebony 1716
    Try cutting the end off of a drill bit and wrapping the rag around it, then pushing the bit end into the drill and tighten onto that. It would give the drill something to grab onto and the rag should stay on until it tears up. Just make sure there's no bit sticking out of the drill end!
    If you have a headlight restoration kit with the drill attachment, either the yellow fuzzy one from Meguiars or the blue foam ball one from Mothers, you can wrap a clean microfiber cloth around that and secure it with a plastic wire tie.
    If wrapped correctly it will not come loose and the wire tie, attached under the restoration kit attachment will not be in play.
    Hope this helps.
    2001, Dragon Green, 1342
    I know the mothers buffer can sell for as much as 34 bucks in some parts houses. Got mine in Wallmart for 19 and change. And you know, the thought of wrapping rags around drill bit's and what have you makes me cringe. Be careful, hate to see a grown man cry
    Jul 2012
    I dont think Bob meant for the bit to be proud of the collette. I will try that. Really even a wooden Dowl would work for that.
    FWIW I bought one of those round Mother's buffers for $20 or so and used it every two weeks for probably a year and a half and it was just as good as the day I bought it.
  1. Wheel Q
    By H3_VX in forum VX Modifications...
    Last Post: 09/19/2013, 07:39 AM
  2. Boring Headlight buffing Picture....
    Last Post: 07/07/2012, 06:45 PM
  3. Need some wheel help
    By boomer27 in forum VX Modifications...
    Last Post: 12/09/2011, 11:50 AM
  4. wheel ?
    By 4x4boy in forum VX Talk...
    Last Post: 06/09/2006, 10:50 PM
  5. 4-wheel LOW
    By Numba1goalie in forum VX Troubleshooting...
    Last Post: 06/26/2005, 04:04 AM
