I am at a crossroads; the front suspension components (upper and lower control arm, knuckle and calipers, among others) are very rusty. The question is do I take the front suspension apart and take a grinder to all of the parts and then spray them with rust converter. Or do I start looking for the parts in the local salvage yards clean them up and paint them? I have a small sand blasting cabinet that will handle most of the parts. I will replace bushings and ball joints as I put things bad together. I have been looking and it appears that Rodeo, Trooper and Ascender parts are interchangable. The only thing that I am concerned about is are there two different knuckle/spindles for 4X4?
I will very likely take the stabilizer off and clean it at the same time and put new bushings on at the same time. Basically, everything on the front suspension is going to be cleaned up. Then I will start to work on the rear suspension. So back to my question, does it make sense to spend a lot of time taking the rust off of the current parts are get ones that are not in as bad of shape. This by the way is more than simple surface rust, it is pretty scaled.
