Results 1 to 3 of 3
Thread: TSB 00-01-s007
    Aug 2010
    01 Foxfire Red Mica VX 0441
    TSB 00-01-s007
    Anyone else had issue with this? My tech researched my high idle and rough shifting out of park and came to the conclusion that its most likely because of this. Only problem is it'll cost me about $150 to have it diagnosed. But anyway, good day for my VX. She got new pvc valve, new air filter and Mobil1 synthetic oil change. Oh, and the tech said he also cleaned the MAF and sprayed the intake manifold for me for free.
    2001 VX
    Mods
    2008 HUMMER H3
    Aug 2010
    Nobody? Maybe i'll post this at the Zoo.
    its been discussed a few times. If you disconnect the pressure sensor while you are experiencing the problem and it goes away.. your pressure sensor is bad.. easy to diagnose, not sure why they want to charge you $150 to diagnose
