I am Trying to figure out what this specifically does. Yes you knuckleheads: I know it gives you more power. So nip that in the bud
The owners manual only mentions to use it when you need more power. Well NS. But I would like to know what it is actually doing. And any cost associated with using it.
) So if that is the case. The rpm shift point change must still be well below its limits.
