Results 1 to 15 of 18
Thread: Head light - Yellow Accent Bulb
    Jun 2010
    2001, White, VX, Ironman Edition
    Exclamation Head light - Yellow Accent Bulb
    Does anyone know the type of bulbs used in the yellow accent light on top of the head light. I'm ref. to the one in the flare bump in the headlights, mine are a yellowish color. I am trying to replace them w. brighter LEDS.
    Thanks!
    Lightbulb
    http://www.vehicross.info/forums/sho...horn%22+lights
    Use "horn lights" as your criteria, in conjunction with the search function, for more read'n material.
    Mar 2012
    sold
    http://autolumination.com/194.htm
    are these the correct ones for the horns? i guess i could measure but thats why im part of this site you all know everything for me
    Jul 2009
    Wisdom is to be imparted, not to be taken...BS, I know, but it sounded good! Not sure on the light specs though.
    Vixer Fixer
    Aug 2012
    99 Ebony Vx's, 0054 & 1548
    You can pick up the yellow (amber) LED's at your local PepBoys automotive, It's LED194 on the package.... also available at Autozone and other toy stores. I think they were $15 for a set... available in red too (rear sidemarkers).
    Life is better when you go Topless
    Mar 2012
    sold
    well you should only have to impart it on me once, then i can impart it to others, so in theory everything you all teach me could end up saving you time - its a win win
    Mar 2012
    sold
    Quote Originally Posted by VxSport View Post
    thanks! i use headlight covers and they dull the original bulbs back a bit so i wanted something brighter and maybe a different color(s) for a change - im assuming the led's are brighter
    Apr 2012
    2001,yellow,vehicross,0901
    what kind of headlight covers are you using Evillecutter? im looking at some GTO covers. but cant decide between the black ones or the Carbon fiber looking ones...
    Aug 2012
    The LED's are 2 to 3 times brighter in the horn position. I put a set of color changing LED's in there. changes 7 diferent colors.
    My original yellow 194's were so washed out (old), they barely were still yelllow.
    Mar 2012
    sold
    Quote Originally Posted by tribalvx View Post
    i got black gto but sent them back for the carbon fiber because the black were VERY dark using stock headlight bulbs and i had to take them off at night - the carbon fiber (which is basically just black with a bunch of tiny holes in it) works much better if you jsut want to leave them on all the time - but if you do go with black they could not be any easier to put on and take off
    Mar 2012
    sold
    can you control what color they are or do they just circulate through them?
    Aug 2012
    The bulbs criculate through the 7 different colors... still trying them out. Waiting to see if the fuzz will pull me over for them. You can only see them up close. so I'm not that concerned.
    so I'm imparting on you by teaching you HOW to fish.....
    HOME PAGE
    VX KNOWLEDGE BASE -(FROM LEFT HAND COLUMN)
    VEHICROSS SPECIFICATIONS
    ELECTRICAL SYSTEM
    and just like MAGIC.....all the bulb types appear!
    or......
    Use the SEARCH bar on HORN BULB
    Mar 2012
    sold
    thanks everyone
    thanks everyone
    yeah, autolumination (and their sister site ctlumination) is very hard to navigate through. Several of us have bought from them. I had a problem with one bulb, they did exchange it, but it was just a hassle.
    I then bought several Chinese cheapies on ebay....and ALL of them burned out very quickly, and in one case, they self destructed when Jack touched it, and split like a banana peel.
    So next, many of us have found "V-LEDs". LittleBeast has used them for quite a while and found them to be top notch!
    They're more expensive, but they have much higher quality items. They come in anti-static packages, and customer service is top rate.
    When I bought some expensive red tower bulbs for my brake lights....I dropped one when pbkid was installing them for me in Moab. It didn't break, but it didn't go brighter when the brakes were applied, and 3 LEDs were out. So Jack installed it as is and I called to buy another when I got back home.
    When I explained I'd dropped it cuz I'm a super klutz, the guy said he'd send me one for free. With that type of cust service, I'm a customer for life!
  1. LED Tail Light Bulb Replacement
    By ALC1717 in forum VX Troubleshooting...
    Last Post: 03/08/2012, 06:34 AM
  2. License plates light bulb
    By Gussie2000 in forum General Tips...
    Last Post: 01/19/2009, 11:22 AM
  3. My new Additions, light yellow lighs and sticker, what u guys think?
    By CoastieCosta567 in forum VX Modifications...
    Last Post: 02/01/2008, 02:57 PM
  4. How to change tail light bulb?
    By Rico_MD in forum VX Talk...
    Last Post: 12/30/2005, 07:14 PM
