Results 1 to 15 of 20
Thread: intermittent rear vibration at 60mph
    Jun 2008
    2001,black, vehicross 1353
    I've done my share of research on here for my current issue. But, before I move forward I'm just gonna throw my symptoms out here for anyone who will comment as i could really use some help with this.
    At approx 60mph and upward I get a loud intermittent vibration and sound from the rear. It goes away upon deceleration. It sounds very much like driving over the vibration strips on the edges of highway lanes to keep you on the road.But it feels like the growl of a bearing. So I believe I've narrowed it down to a rear bearing or differential problem. It absolutely has a bad bearing feel but it feels like its coming from the center of the rear.
    I've checked the tires and rims, the wheel weights are intact, my ujoints are solid my driveshaft hasn't thrown a weight. I do not want to start with things that it obviously isn't-such as rebalancing, alignments etc. I have about 80,000 miles and had the rear diff fluid done at around 60,000 with correct fluid.
    What do I tell the shop to fix/replace and any guesses on cost?
    Please help.
    Milwaukee WI
    Jun 2008
    I'm not opposed to crackin' open that rear pumpkin' and seeing what the fluid looks like smells like and do whatever, perhaps i caught it early enough to change the fluid and limp her along another 25,000 miles?
    I didn't personally do the fluid either, I had a oil change place do all my fluid after I bought it with 55k on it. I specifically told them about the LSD-5 or whatever and I even had them call an Isuzu dealership to verify they were using the right stuff. I was very much a newb back then but I did insist that.
    Yes, check your rear diff fluid (both level & for metal shavings). It may be as simple as low level.
    Remember though that gear oil smells pretty bad even when new. Don't mistake that smell for burnt fluid.
    Jun 2008
    If it doesn't "leak out" (i haven't ever seen any leaks ) could it still be low?
    Yah, you can usually spot leaks ... but not always. If the leak is out by the wheel, the oil may get blown away before you'd notice. Murphy's law does apply to the VX.
    Remember a sage piece of advice though: ALWAYS remove the fill plug first, NEVER the drain plug first - just in case you can't get the fill plug out. Ya can't drive with an empty differential. IIRC, credit goes to etlsport for that one.
    Feb 2004
    '01 Ebony #0830
    If you are lifted too high, you will get that grinding. I was using OME 919s plus DAYSTAR spacers and it was really bad. Removed the spacers and it was manageable by greasing the driveshaft. Try greasing first. It helps.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Mar 2012
    sold
    i had to have a rear wheel bearing replaced but the noise didnt start at 60mph it was basically always there
    Jun 2008
    I lifted with Old Man Emu 912's 4 yrs. ago and haven't had an issue besides the general whine on acceleration at freeway speeds and a very light grumble on decel. This is a different & more noisy/feely thing...but tonite (when i get outa work) I'll start with greasing the driveshaft and I'll check the rear diff fluid out. I wish I had off today! Thanks for the help folks
    Quote Originally Posted by SilverBullet75 View Post
    +1, I was getting a grinding noise from the driveshaft u joints until I started greasing them regularly. I would only get the vibration/noise at highway speed, so it seems to fit the problem.
    2001,FOX FIRE RED MICA,0251
    There is no such thing as rear wheel bearings,front ones but not rear ones
    Mar 2012
    sold
    Quote Originally Posted by WILLY View Post
    autozone and my rear wheels say differently:
    http://www.autozone.com/autozone/par...Rear/_/N-ah8dj
    Jun 2007
    2001, Proton
    Talking Neato
    Isuzu warranty paid for my rear wheel bearings to be replaced. I guess they didn't know the VX didn't have any.
    Carter Pewterschmidt
    '01 Ebony #0939
    ...greasing the driveshaft. Try greasing first. It helps.
    X2
    Jun 2008
    Evilcutter, was it a bearing by the wheel hub or something in the center of the axel if you recall? Do you remember what it cost?
    Mar 2012
    sold
    i dunno i had the work done when i had just bought it and the guy (only mechanic trust) said it needed a new bearing (he pointed to the drivers side rear wheel) and that's why it was loud - i cannot find the receipt but i think it was about $450 parts and labor for the bearing, all the rotors to be turned,all new front pads, and one new front caliper - sorry prob doesnt help much if i see him soon ill ask
  1. intermittent a/c
    By stevo2deep in forum VX Troubleshooting...
    Last Post: 06/05/2012, 09:06 AM
  2. TOD "CHECK LIGHT"...intermittent at 60mph plus
    By JoFotoz in forum VX Troubleshooting...
    Last Post: 04/06/2009, 07:00 PM
  3. What about intermittent windshield wipers?
    By ScottinMA in forum VX Modifications...
    Last Post: 03/09/2005, 01:11 PM
  4. Pole + Yukon@60mph = Ownage!
    By volume311 in forum VX Talk...
    Last Post: 07/24/2004, 08:07 PM
  5. intermittent(sp?) missfire
    By TDUB in forum Meets...
    Last Post: 03/01/2004, 08:53 AM
