You would think so but the passes here top out at 11-12k feet so that alone drops your power by up to 40%. Then figure in the runs up them can be 10 miles of 6-8% grade all up hill with 65 mph speed limit and you need power to get up them unless you want to follow the big trucks all the way up at 10mph.
The DOHC 3.2 (which is the non stroked 3.5) also has oil burning issues. Isuzu considers 1 qt per 1k miles normal but I've seen them burn much more. Mine burned 1 qt per 3k miles most of the time I've had it but the last couple years its started to guzzle it.Actually, the 3.2L from the rodeo has been shown to fit (on this forum) and does not have the same oil burning issues as the Trooper/SLX/VX 3.5L.
