I am having issues with my brakes. I remember another post with similar issues but can't find it (searching brakes brings up a ton of posts).
So here is the problem...
basically brake pedal is harder than usual to push, braking is weak. No strange noises. Pads/rotors are good. My abs has not worked in forever. Fluid is full.
Would air in lines cause this? Anything else to check?
