Hello All,
Well, now that I have decidd to not part her out, I am going to start looking into these problems.....
She has been sitting for over a year. I put a new battery in it, and started it up....her is what I have noticed:
1. Engine knocking, but no codes / not leaking oil. Any suggestions on
where to start looking??
2. Power steering fluid reservoir very low. Would moving the car / turning
the sterring wheel with no power cause fluid loss? Cause fluid to leak
out??
3. Transmission slipping. I assume it's due to the fluid being leaked out. He
thought this was oil, but clearly its tansmission fluid. Where are the most
common spots for leaks??
The prior owner said all of these problems seem to have centered around a car wash, and immediately after him spraying the engine down with the high pressure hose. Coincidence, or could there be seom connection?
I will begin scouring the site for info, but any quick tips would be greatly
appreciated.
