Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Engine Replacement - Axiom vs. 6VE1
    Jan 2008
    1999 Astral Silver 0481
    Giz and Gus, the oil drain hole issue is one that I have heard before, and them plugging up is one of the reasons why some of these engines grenade themselves at a relatively young age. I don't think mine is an oil starvation issue, though the engine has always used a LOT of oil (3/4 of a quart of oil every 300-350 miles). I've always stayed on top of it and she's run like a champ up until now. From the research I have done I believe that there is something going on with the piston, rings, or cylinder itself. Maybe that is an oil drain hole issue though. Leak down test on Friday will tell a little bit more about what's going on.
    I had also heard the same things about the Axiom engines. The direct injection engine won't fit in our VX's due to them using a different transmission, and the Axiom engine's that would fit in our VX's came from and '02-'03 Axiom with an "X" as the eighth digit in the VIN. I think the "X" denoted the four wheel/all wheel drive option in the Axiom which meant it was basically using our transmission and transfer case.
    If a rebuilt engine will solve the oil burning issue that would be great. Dave, do you have any contact information for Jerry Lemond? I've heard of this fabled Isuzu guru, and it would be great to talk to/ email with him to get his opinion on engine re-builders, engine options, things to look out for, etc.
    You may want to check planetisuzu and get more info/details in regards of the rebuild.
    I heard few times that after rebuild the oil issue is no longer a fact,but that may vary depending on which rebuild kit and mechanic do the job
    Dakar was just the begining.
    May 2007
    1999 Black Rodeo
    you can either pm Jerry on planetisuzoo or email him at jlemond at bellsouth dot net
    --Dave
  1. Axiom engine
    By Nikad92397 in forum VX Modifications...
    Last Post: 09/17/2016, 05:51 PM
  2. My Axiom engine install 6VE1 (late)
    By Espritmike in forum VX Talk...
    Last Post: 11/18/2013, 09:10 AM
  3. Update on VX with Axiom Engine
    Last Post: 06/05/2009, 04:33 AM
  4. Has anyone DONE the axiom engine swap?
    By ilya in forum VX Modifications...
    Last Post: 01/13/2009, 08:49 PM
  5. Replies: 1
    Last Post: 06/19/2004, 04:36 AM
