Results 1 to 15 of 22
Thread: what might cause gas cap to seize up?
    Sue,
    If the stealership can't figure out what's going on then I'd suggest your next step should be another aftermarket cap. But before you start using it, drill a hole in it for a vacuum release screw (or even a Schrader valve).
    Not sure if that's your problem but it's the next logical step to take.
    Would that trigger a CEL because of the vapor or fumes?
    Jun 2007
    2001, Proton
    Have you tried
    screwing on a little less tight. Our VX cap says 3 clicks.
    Carter Pewterschmidt
    That's why I suggested a screw plug or a schrader valve. It'll act just like an un-modified cap until you release the pressure (or vacuum). The only problem I can foresee is that a schrader valve functions on positive pressure - it may leak if it's seeing negative pressure (vacuum). On the other hand, that might be mo betta.
