Results 1 to 3 of 3
Thread: need help with TIRES size !
    Hi to all ! I'm going to purchase set of off-road tires , i also have 18" rims , whats the optimal tire diameter/dimensions will fit VX?
    I'm thinking of 33" tires , am i wrong? If anyone can post a link with the best off-road tires for city driving i will appreciate it
    Aug 2008
    On a "non-lifted" 100% Stock VX, there is really only one choice and here's why:
    http://www.tirerack.com/tires/tires....omCompare1=yes
    TIRE: General - Grabber AT2 (All-Terrain)
    SIZE: P275/65R18 (32" O.D.)
    SUPER LIGHT-WEIGHT: Only 42.4 lbs each (per factory website).
    SPECIAL RATING: Snowflake/Mountain rated.
    INEXPENSIVE: About $190 per tire (+/-).
    SUPERB TRACTION: Both on & off road; incredible on snow & ice.
    NOISE LEVEL: Whisper quiet on the highway.
    GREAT LOOKS: Very agressive appearance.
    Bolt-on perfect on a 100% Stock VX when using OEM 18x7 factory rims, with only minor trimming on front innerside cladding. No lifting required.
    99" silver Vcross #1307
    I do know from giveing them a try, if you go bigger than a 265 your performance goes way down, and if you change the gear its ok but the power{horsepower} just isn't there for the new gear.
  1. Replies: 11
    Last Post: 11/05/2012, 01:22 PM
  2. What size
    By tom4bren in forum General Tips...
    Last Post: 09/27/2007, 12:01 PM
  3. Replies: 2
    Last Post: 07/26/2007, 02:40 AM
  4. Rim size/Tire size
    By Dumke in forum VX Talk...
    Last Post: 01/31/2007, 04:00 PM
  5. Fat tires or skinny tires?
    By Teckhardt in forum VX Modifications...
    Last Post: 05/05/2003, 08:00 AM
