Results 31 to 31 of 31
Thread: another rough idle problem
Threaded View
    Mar 2012
    sold
    i know there are more than one post about the rough idle and im going through the steps to see what i can do but i have a few questions i havent found answers to yet - the whole thing started when i came back home and the engine was running perfectly - i go for a short drive and notice a little flutter like its not getting enough gas at a stoplight - get it back home and shut it off and i cant start it back up - pop the hood and try to start it again and it revs to 2k then back to 1k but still really rough idle - cleaned the pcv valve (again) and replaced the idle control valve but no change - ordered a new fuel pressure regulator and will try that next - ive also read that it could be the intake manifold gasket or the throttle position sensor which ive never replaced either before but im ready to do both if necessary - my question is what might be the best order to replace these and where exactly is the throttle position sensor? im dreading taking off the intake minifold... side notes: no check engine light, and this has happened once before but just the low idle not the dancing around of the tach - thats whan i changed the fuel filter and put a can of seafoam in the gas tank - all good for 3 months now this - like always any help is much appreciated
  1. Rough or intermittent idle?
    By yesitdoeshaveteeth in forum VX Troubleshooting...
    Last Post: 02/13/2011, 08:36 PM
  2. rough idle w/ AC
    Last Post: 10/22/2010, 08:51 AM
  3. New VX Owner and Rough Idle
    By Sweetnuts in forum VX Troubleshooting...
    Last Post: 07/07/2006, 01:36 PM
  4. Rough Idle
    By VX FIX in forum VX Troubleshooting...
    Last Post: 03/15/2006, 06:24 AM
  5. FINALLY: Rough idle and stalling problem fixed!
    By Yefim in forum VX Troubleshooting...
    Last Post: 08/19/2004, 08:45 PM
