Results 16 to 30 of 31
Thread: another rough idle problem
Threaded View
evillecutter another rough idle problem 07/05/2012, 07:24 AM
VXR When this happened to me it... 07/05/2012, 12:20 PM
evillecutter got home today and it is... 07/05/2012, 02:11 PM
Ldub I'd guess that's possible, as... 07/05/2012, 02:53 PM
Y33TREKker Having only replaced the fuel... 07/05/2012, 05:31 PM
evillecutter might sound stupid but... 07/06/2012, 06:12 AM
Y33TREKker It's on the side of the... 07/06/2012, 10:04 AM
Ala5ka did you actually replace or... 07/05/2012, 09:12 PM
evillecutter i only cleaned it because... 07/06/2012, 06:13 AM
evillecutter well its back after driving... 07/06/2012, 12:24 PM
99_VX Since I was having a similar... 07/07/2012, 01:20 PM
evillecutter left the negative battery... 07/09/2012, 12:22 PM
evillecutter update: 3 weeks later and it... 08/01/2012, 06:21 AM
jasonm621 I have recently had the EXACT... 08/01/2012, 07:53 AM
evillecutter thanks jason i'll give it a... 08/01/2012, 09:20 AM
jasonm621 Its a bugger. You would think... 08/01/2012, 10:43 AM
evillecutter thanks again - gonna try if i... 08/01/2012, 11:38 AM
evillecutter tried your tps unplug and it... 08/03/2012, 01:51 PM
jasonm621 Glad to hear it! 08/06/2012, 03:13 PM
evillecutter so about a week after i... 09/11/2012, 06:11 AM
evillecutter its back - any suggestions... 01/02/2014, 08:46 AM
evillecutter looks like a $3.00 bottle of... 01/07/2014, 01:42 PM
magikmike Check the Air temp sensor,... 01/07/2014, 04:30 PM
evillecutter thanks mike ill check it out! 01/08/2014, 06:51 AM
44ficus44 anyone on this post had the... 01/08/2014, 01:04 PM
VXR Mine is doing that right now.... 01/08/2014, 05:58 PM
44ficus44 yea its come down 2 that for... 01/09/2014, 11:28 AM
evillecutter i dont think my is the... 01/09/2014, 11:43 AM
44ficus44 It is.. thats why i dont want... 01/09/2014, 11:49 AM
evillecutter http://www.youtube.com/watch?v... 01/09/2014, 12:11 PM
44ficus44 hey, does anyone know exactly... 01/10/2014, 11:34 PM
    Mar 2012
    sold
    i know there are more than one post about the rough idle and im going through the steps to see what i can do but i have a few questions i havent found answers to yet - the whole thing started when i came back home and the engine was running perfectly - i go for a short drive and notice a little flutter like its not getting enough gas at a stoplight - get it back home and shut it off and i cant start it back up - pop the hood and try to start it again and it revs to 2k then back to 1k but still really rough idle - cleaned the pcv valve (again) and replaced the idle control valve but no change - ordered a new fuel pressure regulator and will try that next - ive also read that it could be the intake manifold gasket or the throttle position sensor which ive never replaced either before but im ready to do both if necessary - my question is what might be the best order to replace these and where exactly is the throttle position sensor? im dreading taking off the intake minifold... side notes: no check engine light, and this has happened once before but just the low idle not the dancing around of the tach - thats whan i changed the fuel filter and put a can of seafoam in the gas tank - all good for 3 months now this - like always any help is much appreciated
  1. Rough or intermittent idle?
    By yesitdoeshaveteeth in forum VX Troubleshooting...
    Last Post: 02/13/2011, 08:36 PM
  2. rough idle w/ AC
    Last Post: 10/22/2010, 08:51 AM
  3. New VX Owner and Rough Idle
    By Sweetnuts in forum VX Troubleshooting...
    Last Post: 07/07/2006, 01:36 PM
  4. Rough Idle
    By VX FIX in forum VX Troubleshooting...
    Last Post: 03/15/2006, 06:24 AM
  5. FINALLY: Rough idle and stalling problem fixed!
    By Yefim in forum VX Troubleshooting...
    Last Post: 08/19/2004, 08:45 PM
