Results 1 to 15 of 19
Thread: Cut 919s to make firm stock height?
    Feb 2004
    '01 Ebony #0830
    Question Cut 919s to make firm stock height?
    Just curious to see if anyone has tried to Cut a couple coils off of OME 919 springs to use on a stock height VX?
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Yes.
    I cut the 919s after installing the body lift so I could bring the VX down a little bit. Works just fine for pavement but I had significant issues this year in Moab with the coil springs unseating because they don't have enough spring length.
    I just borrowed a set of stock coil springs from Mdwyer and installed them yesterday with a 1" spacer. I'll be buying them from Mdwyer if they fix the problem.
    My chopped 919s might be available if you want to test them out before cutting your good springs.
    Feb 2004
    '01 Ebony #0830
    Interesting!
    Cool.
    How did it feel on-road?
    The same. Maybe a little stiffer because I cut out some of the progressive coil springs.
    Feb 2004
    '01 Ebony #0830
    Cool.
    I'll let you know!
    Thank you!
    Oct 2003
    1995 Isuzu Trooper LS
    Have you looked into the 913s? They are 40mm shorter than the 919s (unsprung), and are intended as a zero lift spring for Troopers. Same wire diameter as the 919s.
    Feb 2004
    '01 Ebony #0830
    Oh.. I thought the 913s were a lift, stiffer than 912s.
    I think Rowhard used them in his VX.
    Oct 2003
    They are stiffer than 912s (should be about as stiff as 919s), and they may result in some lift on a VX, don't know. On a Trooper they are zero lift...but the rear end of a VX is a lot lighter than a Troopers.
    2001, Ebony Black, 1153
    Please don't cut springs.....
    Jan 2012
    2001, Ebony Black, VX
    The 913s will give about 1.75" of lift on the VX. I just installed mine earlier this year. I love them!
    '03 Honda CR-V (DD) - '05 Jeep Wrangler Rubicon - '01 Ebony VX!
    A smile is like tight underwear, it makes your cheeks go up!
    Quote Originally Posted by jeeperkate View Post
    I agree, the 913s are a good option.
    OME913
    Free Height: 390 mm., 15.35 in.
    Number of Coils: 9.3
    lbf/in spring rate: 180-300
    Application: (medium Amigo/Rodeo 5door coil spring 98-02)
    ________________________________________________
    OME912
    Free Height: 420 mm., 16.54 in.
    Number of Coils: 10.8
    Application: (medium load Trooper 92-02)
    OME919
    Free Height: 430 mm., 16.93 in.
    lbf/in spring rate: 200-280
    Application: (heavy load Trooper 92-02)
    '01 Proton #0317
    Cutting springs is the "redneck" way to TRY to make a vehicle work. I'm no engineer (I just play one on TV), but cutting anything more than 1/2 a wind off a spring, ESPECIALLY a progressive spring, totally changes its performance characteristics - NEVER for the better!
    If you take the time to study the data that IS available on each and every spring, you should be able to make a pretty good educated "guess" at how it's going to perform in your given application. Apparently there are a number of choices out there for the VX - take your time and do your homework!
    2001, Dragon Green, 1342
    Quote Originally Posted by SilverBullet75 View Post
    No me. Only mod was Rancho's and torsion bar crank to help the wheel/tire fit.
    Here is the link to Rickshaw's 913 Experiment; http://www.vehicross.info/forums/showthread.php?t=15476
    Feb 2004
    '01 Ebony #0830
    Sorry Rowhard, mixed up the names.
    Guys, I have already done the research on the available options for the VX. (that's why I'm using 919s on my lift). All of the OME springs LIFT the VX. The question is for a STOCK height VX. I'm actually asking this with another person's VX in mind. There are no aftermarket options for stock height. That's why I'm asking about cutting 919s.. Or even the expedition version.
    Oct 2006
    01 Green Dragon 00291
    I'm going to order some 913s right now!
  1. Replies: 13
    Last Post: 02/14/2013, 10:02 AM
  2. Seat height issue
    By housertl in forum VX Troubleshooting...
    Last Post: 06/24/2011, 09:24 AM
  3. Height adjustable air system.
    By kodiak in forum VX Talk...
    Last Post: 05/22/2008, 03:10 PM
  4. Stock ride height?
    Last Post: 02/01/2004, 12:05 PM
  5. Level ride height
    By RobVX in forum VX Troubleshooting...
    Last Post: 05/25/2003, 01:23 PM
