Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Cut 919s to make firm stock height?
  1. #16
    Quote Originally Posted by SilverBullet75 View Post
    Guys, I have already done the research on the available options for the VX. (that's why I'm using 919s on my lift). All of the OME springs LIFT the VX. The question is for a STOCK height VX. I'm actually asking this with another person's VX in mind. There are no aftermarket options for stock height. That's why I'm asking about cutting 919s.. Or even the expedition version.
    Despite what others say about cutting the springs, it worked fine for me. I don't see any issue with cleaning cutting a ring or two off the 919s. Just don't use a blow torch because the heat will ruin the springs. Band saw works great.
    I also looked into the other options when trying to get the perfect ride height. I found Moog makes coil springs that should fit the VX. There's a wide range of heights & different spring rate. I believe we need a coil springs with tangential & square ends.
    http://www.moog-suspension-parts.com...il_Springs.asp
    I was planning on test fitting a few of them before I decided it was a lot less time, effort, and money to cut the coil springs and move on to the next project.
  2. #17
    Feb 2004
    '01 Ebony #0830
    Thanks VXorado!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
  3. #18
    '01 Proton #0317
    You can also get custom springs wound to your specs; it ain't that expensive either...
  4. #19
    Aug 2011
    2000, Dragon.
    Anyone know the stock spring rates?
  1. Replies: 13
    Last Post: 02/14/2013, 10:02 AM
  2. Seat height issue
    By housertl in forum VX Troubleshooting...
    Last Post: 06/24/2011, 09:24 AM
  3. Height adjustable air system.
    By kodiak in forum VX Talk...
    Last Post: 05/22/2008, 03:10 PM
  4. Stock ride height?
    Last Post: 02/01/2004, 12:05 PM
  5. Level ride height
    By RobVX in forum VX Troubleshooting...
    Last Post: 05/25/2003, 01:23 PM
