Results 1 to 9 of 9
Thread: Idle rev issue- No solution yet...
    Aug 2005
    1999, silver, 0887
    Did you get any codes? Like 171???
    2000, Ebony, VX, 0370
    Thanked: 12
    I was getting three other codes, but all of them delt with oxygen sensors. I can't remember all of them, but I was getting P1171 (Fuel System Lean During Acceleration), P03something, and P05 or 7-something. All of those went away when I did a thorough clean of the EGR and MAF sensor.
    P0303 (cylinder three mis-fire) is sticking around, though. The code always seems to happen during a sustained idle and usually after the engine is up to operating temperature. She has a rough idle now, and from the research I have done here are some of the possible causes:
    -Faulty spark plug or wire (don't have those, but haven't checked the wire leading to the coil pack yet)
    -Faulty coil (pack) (have switched the coil packs and mis-fire stays at cylinder three)
    -Faulty oxygen sensor(s) (haven't checked these yet, but figured that they would throw their own code)
    -Faulty fuel injector (haven't checked this yet, and frankly don't know how to)
    -Burned exhaust valve (man I hope not)
    -Faulty catalytic converter(s) (possible, but "rotten egg smell" that is supposed to point to a bad cat isn't really present)
    -Running out of fuel (tank is full)
    -Poor compression (haven't checked this yet)
    -Defective computer (wouldn't know how to check this)
    I've also read on here that others have had similar problems and it was a bad intake manifold gasket. I got some starter fluid this morning that I will spray around the intake tomorrow to see if the idle changes any.
    Any other suggestions would be most welcome.
  1. Fast idle, low idle, (stalling) temp gauge all over the place.
    By Nikad92397 in forum VX Troubleshooting...
    Last Post: 11/07/2016, 08:48 PM
  2. Another Idle issue
    By housertl in forum VX Troubleshooting...
    Last Post: 09/27/2011, 06:29 PM
  3. Engine Idle Issue - TRIED EVERYTHING!
    By KRemo in forum VX Troubleshooting...
    Last Post: 07/12/2009, 07:50 PM
  4. muffler solution
    Last Post: 10/19/2007, 06:12 AM
  5. Is there a solution?
    Last Post: 03/14/2004, 07:04 PM
