Rear Wheel Speed Sensor Connector Colors? Shoulda Had a Lift/ Most Expensive Garbage
Well I had a fantastic run-in with a large bag of garbage on the highway a month or so ago which somehow managed to wrap a cable TV wire, a sweater, and some netting around my drive shaft
: In the process, it managed to rip up the wiring to the ABS rear wheel speed sensors, hence the shoulda had a lift/ most expensive garbage ever tag line in the post title!
The question:
What color connector goes to which side?
I see what used to be a set of orange or faded red connectors and a complete set of black but after searching the forum and reading the ABS section of the repair manual still haven't found which color goes to which. I guess I could just try each one and see or guess based on which side they lie on, but the wires are cut so it isn't quite as easy and I figured I'd ask! Each connector has two wires entering and exiting, one white and one black I believe. When I get a chance hopefully I will post some pics of the garbage all tangled up!
'00 VehiCross Ironman, 2003 MR2 Spyder 5 speed Yellow, 2001 MR2 Spyder Black [Blown Engine], '99 Rodeo [Deceased], '92 Mazda Miata 5 speed [Deceased], 1981 Baja 170SS
