Results 1 to 7 of 7
Thread: intermittent a/c
    Nov 2010
    1999 Astral Ironman 1190
    intermittent a/c
    Hi all,
    I have searched for something similar but everything seems to come up blower motor or relay, which I have replaced within the last year. Does any one with a 99 have their a/c only work randomly? I can drive to work with the fan working and be able to turn a/c on, but on my way home after startup no fan, no light on a/c, but maybe when I pull into the drive way the damn thing kicks on?? Could this simply be the blower again after all? I guess what I'm asking is if it is possible for the blower issue to cause the A/C light to not come on as well or is there maybe something else I should look at. Thanks for looking
    '01 Ebony #0939
    Does the A/C system pressure (freon charge) check ok?
    Nov 2010
    well that I can't say, but when a/c does come on it is cold as should be
    '01 Ebony #0939
    I ask because a system charge that's too high or too low can result in an intermittently activated A/C Triple-Pressure Switch. It acts as something of a safety switch for the components in the system because pressure that is too high can result in blown seals, or component failures when pressure (and as a by-product, system lubricant) is too low.
    Since no A/C system is perfect, there can be leaks over time causing low pressure, and if a person doesn't exactly know proper procedures for adding freon to a system, too much can be added causing pressure to be too high which can be just as bad.
    May 2007
    1999 Black Rodeo
    Dont think its the charge. The light for the a/c button would still be on. There is a bad connection somewhere. I have the same issue on my rodeo but it only happens occasionally so I'm not able to track it down.
    --Dave
    This may seem really off the wall, but I have a similar issue with my '82 Mustang, and the problem with mine is the IGNITION SWITCH. When I start the car I have to very gentle rotate the key back a few degrees in order for the electrical contacts to engage. I learned this trick from my '70 Torino that did the same thing, except all the gauges would read high. (Maybe it's a Ford thing.)
    Gregg
    2001 Proton Yellow #1379
    Nov 2010
    well cobra that's about the only thing I haven't bothered jingle jangling. I will give that a try and let ya know
  1. intermittent A/C when i accelerate ((weird))
    By vxodus in forum VX Talk...
    Last Post: 06/27/2013, 10:09 PM
  2. intermittent rear vibration at 60mph
    By djvx in forum VX Troubleshooting...
    Last Post: 08/28/2012, 08:38 PM
  3. Rough or intermittent idle?
    By yesitdoeshaveteeth in forum VX Troubleshooting...
    Last Post: 02/13/2011, 09:36 PM
  4. What about intermittent windshield wipers?
    By ScottinMA in forum VX Modifications...
    Last Post: 03/09/2005, 01:11 PM
  5. intermittent(sp?) missfire
    By TDUB in forum Meets...
    Last Post: 03/01/2004, 08:53 AM
