When I did my brake job and read up on how/why to bleed the brakes on the VX what I got out of it was that the brakes are power/ power assist so the engine needed to be running to make sure that the pressure was up high enough to push all of the fluid/ air bubbles through the system. As for pulling the ABS fuse; the ABS unit itself holds a good bit of fluid in it so in order to get the brake fluid/ air bubbles out of it, you have to pull the fuse to disable the ABS so, for lack of a better term, it opens up and allows fluid to pass through it. If you leave the fuse in then the ABS unit doesn't "trip" and it stays outside of the loop and fluid doesn't pass through it. With the unit disabled, it becomes part of the loop and allows fluid to pass through it. That's my understanding......but I could be TOTALLY off.
dynofan, I don't ride the pedels either, but our gas and brake pedels are so close together that I have accidentally hit the gas a couple of time while stepping on the brake, and it is a bit disconcerting when you think you're just stepping on the brake, but the engine revs up a little and the VX lurches forward.
The brake booster is a big drum that is on the firewall right behind the brake master cylinder. If you open your hood, the brake master cylinder and brake booster are on the right side, right in front of the steering wheel. The master cylinder has the brake fluid reservoir on top of it.
