Muffler bearings?
					Actually, muffer valves is the topic here...
Talking to Jerry Lemond about the less-than-linear sound my exhaust makes.  Light throttle and heavy throttle are perfect.  Some partial throttle openings can be less than robust...maybe a bit turbulent, un-tuned, or whatever.  I liken the sound to a loud radiator fan (for lack of better description).
Oddly, it seemed more frequent/prevalent when cold AND even with more incidence.   IOW, if I stay away from that range, it didn't seem as prevalent when going thru it.  I had a muffler shop take a look and contemplated a Dynomax ST or Walker Quiet III.  If, for no other reason, to get a more sophisticated sound through-out the rpm ranges.
Enter my conversation with Jerry.  First thing he tells me is his Trooper has a muffler with internal valve.  It's used to promote faster warm-up of exhaust (probably CATs I bet).  Sounds very similar to these Dynomax VT mufflers (with the valved opening).
My question is whether anyone can confirm/deny the presence of a valve inside our factory mufflers?  Jerry's not sure.
Or, if other ideas come to mind on my quirky exhaust sound, let me know.  (I'd  almost call the cold, warm-up sound akin to cars with a loose manifold heat shield.  But, it really doesn't buzz/rattle.  It's just turbulent and tinny.
