Results 1 to 15 of 19
Thread: front left boot bad, losing grease, "might as well replace axle while at it
    Dec 2011
    2001, white, ironman, 0431
    front left boot and axle replaced
    Had my front left boot and axle replaced to cure the noise as diagnosed by mechanics of a national chain ($300 parts and labor). As I drove away, I heard the same noise as before even with the first turn of my wheels ! I u-turned back in and gave the mechanic a ride to hear the noise. He confirmed it and the manager is researching the issue.
    How do these boots fail in the first place ?
    Are the boots moved or adjusted during a lube-job ?
    Thank you for the past help with this issue and my blown fuse !
    Jun 2007
    2001, Proton
    It is just the nature of the part
    Quote Originally Posted by dmanske@cavtel.net View Post
    Made of flexible material constant exposure to elements constant flexing while driving they just wear out. The boots are not touched on a lube, whichis really passe. The oil change joints dont even do that any more and we have a closed system with only the drive axle needine lubed. Which you should do regularly
    Carter Pewterschmidt
  1. CV boots (or replace both front left and right axles)
    By VXD959 in forum VX Troubleshooting...
    Last Post: 03/29/2013, 04:40 AM
  2. Changing CV joints (front right and left axle assemblies)
    By mcaramb in forum VX Troubleshooting...
    Last Post: 04/11/2012, 04:54 PM
  3. cv boot grease leaking
    Last Post: 07/23/2010, 10:53 AM
  4. ABS Light ON - Left Rear Wheel Speed Sensor "Open"
    Last Post: 02/17/2009, 08:00 AM
  5. My turn to replace a CV boot
    Last Post: 11/01/2006, 10:01 AM
