Heard a scraping noise at the same frequency that the wheels were turning. Thought it was on the right side. Local shop found damaged boot on left side allowing loss of grease. They recommended replacing left front CV axle since labor about the same to replace boot as to replace boot and axle. The estimate for parts and labor is $300. How does this sound to you more knowledgeable and experienced out there than I ? Thank you ! Den
