Results 1 to 6 of 6
Thread: No Power (12 volt)
    Sep 2009
    1999 Astral 1052
    Wrench No Power (12 volt)
    I have a 99 and it has been sitting for a while. I went to crank it up and there are no indications of 12v power anywhere except at the battery. I pulled the battery and charged it thinking that might be the problem but still nothing. I have about 13v at the battery terminal and on the "Main" fuse.
    When I say no power I mean nothing (with key on or off) - no horn, interior lite, head lights, no turn signals, no dash lights, etc.
    Anybody have any good advice??????
    Thanks
    Ed
    Is there power on both sides of the fuse?
    Aug 2005
    1999, silver, 0887
    Sounds like a bad ground cable from the battery.
    Sep 2009
    1999 Astral 1052
    12v on both sides and I thought about the ground but have not found any place it is bad. Is there any place that may be a common problem?
    Thanks
    Ed
    Yep, sounds like a ground issue. Check the cable at the terminal for corrosion, find the ground point and make sure it hasn't come loose or corroded. Those are the usual areas. The ground cable breaking is usually not going to happen.
    Also sometimes the lead terminal on the battery will wear down so the cable terminal doesn't clamp tightly on it.
  1. Engine Compartment 12 volt acc wire
    By Bird Dog 36 in forum VX Talk...
    Last Post: 10/17/2014, 05:48 PM
  2. HELP..with Hi Power Wi-Fi please.
    By JoFotoz in forum Chit-Chat ...
    Last Post: 01/27/2013, 12:44 PM
  3. Power!
    By D-19 in forum VX Modifications...
    Last Post: 04/14/2008, 09:37 AM
  4. Serious DIY sub power
    By Dallas4u in forum VX Talk...
    Last Post: 03/05/2004, 01:58 PM
  5. Need of Power!!!
    By Radiologue in forum VX Modifications...
    Last Post: 05/29/2003, 09:57 PM
