Results 1 to 15 of 16
Thread: Rear end chirp.
    Dec 2003
    Former Owner 0216
    Rear end chirp.
    It's a medium sound and I hear it best when I am turning and when there are bumps. Sounds like suspension, but I am not sure. I just replaced the front whee bearings and all that noise went away, so now I am hearing all the others.
    Any thoughts on where I might start?
    2000, Ebony, VX, 0370
    Thanked: 12
    Could be the sway bar bushings squeaking. Do you have the greasable bushings?
    Aug 2005
    1999, silver, 0887
    Yep. Sway bar bushings/mounts. Buy some spray silicone with a long nozzel, and stick it in the mount and spray away those sounds, do front and back.
    Quote Originally Posted by crager34 View Post
    Noises are tough, & sometimes aren't coming from the area you think.
    Put a few wraps of duct tape around the loop that engages the hood latch, latch the hood, then take it for a test drive.
    It's an easy test, & could be the culprit.
    Since "chirp" was in the title, it makes me thinks hood latch, suspension usually sounds like a squeak to me.
    Feb 2004
    '01 Ebony #0830
    Wink Am I the only one with a 13 yr. old's mind?
    Sounds like gas to me...
    Beano works well.
    LOL
    Seriously though... I have that same squeak. Annoying and embarrassing. Here I go driving around my residential area, cool exhaust note at 2500 RPM, go around a bend... hit a bump and SQUEAK SQUEAK!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Quote Originally Posted by SilverBullet75 View Post
    Since I resemble that remark so closely, I would answer: NO...
    Mar 2010
    2001 Ironman 0588
    I agree with others that noises can be hard to locate. Are you 100% sure it's coming from outside? My back seat chirped over bumps (went away when I folded/rolled it forward) and now an interior body panel in the back chirps (fastener has slipped out of the hole and it's rubbing against the sheet metal like a needle on a record.)
    Me too. I immediately thought of this.
    Feb 2004
    '01 Ebony #0830
    Wink
    That's awesome! LOL
    I just giggle when reading the current thread titles:
    Thumping while going uphill...
    Rear end noise when coming to a stop...
    Rear end chirp...
    Wait.... trying to grow up...
    Darn. Failed.
    Oct 2004
    99 Victory White Ironman 0685
    X2...It has been so long since I fixed that.I had forgotten about it!
    Chi Dog...Dog is my Co-pilot
    Onward thru the fog
    Aug 2005
    1999, silver, 0887
    Post
    I tried this technique and it works. It solved a vexing problem. I am grateful for the advice.
    Mar 2012
    2001,Ebony Black,VehiCross,0565
    I'm trying to track down my own trapped little birdy chirp!
    I'll start with the hood latch and diagnose from there.
    Mechanic said he couldn't hear it, but he also had the air con and radio on...duh.
    Thanks for the tip Ldub!
    Dec 2003
    Former Owner 0216
    Performed the duct tape hood latch wrap and the rear bushing lube. Hear that?
    chirp chirp...... Well... ok... not the best way to put it, but the noise did stopped.
    Thanks everyone.
    Aug 2005
    1999, silver, 0887
    Bravo!
    Mar 2010
    2001 Ironman 0588
    Congrats!
    Mar 2012
    Same here!
    Duct tape = No more squeak!
    I think that's worthy of a paypal donation to the site. Thanks all!
  1. Front and rear (rear) driveshaft joints are different?
    By 89Vette in forum VX Troubleshooting...
    Last Post: 10/05/2013, 09:02 PM
  2. Squeak, chirp finally conquered
    By bartmanS4 in forum VX Troubleshooting...
    Last Post: 02/14/2013, 09:53 AM
  3. Fast chirp sound from front end
    By samneil2000 in forum VX Troubleshooting...
    Last Post: 06/23/2009, 07:44 AM
  4. High pitched chirp or squeak
    Last Post: 01/29/2006, 12:26 AM
  5. Beep Bleep.... Cheep Chirp
    By transio in forum VX Talk...
    Last Post: 07/10/2005, 06:57 PM
