The previous owner had the radiator replaced and I believe used the wrong size lines that run to my trans. One or both lines leak at the connection despite being extremely tight. And I have a ton of slack on the lines because they hang down. Can anyone confirm the correct size and length for these lines? Or is that info useless because the radiator has been replaced and the new one requires a different size. I'm hoping to tackle this messy job tonight and then add more trans fluid.
