Results 1 to 8 of 8
Thread: Need help for power steering gear box
    Apr 2012
    1997silver
    Hi, my VX's power steering gear box is leaking oil. I can't find new replacement part. Anybody know which model's power steering gear box is commonize with VX'S. Appreciate your help!
    Kong,
    Mine leaks too but I've almost gotten it to stop with Lucas. May be worth a try before you drop the ching on a new gear box.
    If you still need to replace the gearbox, give Merlin a call. He should still be able to get one for you.
    Apr 2012
    1997silver
    Dear Tom
    Thanks.
    Jul 2004
    2000, Kaiser Silver, 0196
    From where is it leaking - input or sector shaft? Somebody on this board recently rebuilt his steering gearbox and maybe he could tell you what size seal it will take. Unless you've got a lot of miles on your VX or you've fed it dirty fluid, it's probably just the seal itself that's worn. You don't need to spring for an entire new box - just yank the old leaky seal out and pound a new one in using the proper size PVC pipe or something similar. 10 bucks and an hour of cursing and you're leak free again.
    If you want to replace all the whole gearbox, Advance Auto, Auto Zone, etc sell rebuilt units for $350 or so and will loan you a Pitman arm puller.
    Here's the thread he was referencing:
    http://www.vehicross.info/forums/sho...t=sector+shaft
    Apr 2012
    1997silver
    Thanks for the guidance and help.
    I will try to replace the seal before order the new box.
    Thanks.
    Jun 2003
    1999 Victory Ironman 1703
    A 98 trooper has the same gearbox. That's what I did. http://www.car-part.com/
    Apr 2012
    1997silver
    Thanks Jonnie
  1. Steering Gear Rebuild
    By XtonVX in forum VX Talk...
    Last Post: 08/22/2012, 07:45 PM
  2. Steering Gear box Hose
    By Jonnie in forum VX Troubleshooting...
    Last Post: 09/10/2011, 02:29 PM
  3. How to drain power steering
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 06:48 PM
  4. steering gear worn out?!
    By Arne D. in forum VX Troubleshooting...
    Last Post: 05/24/2005, 11:37 PM
  5. power steering hose
    By monkeyhaas in forum VX Talk...
    Last Post: 12/08/2004, 08:49 PM
