In looking at the second of the last pics you posted, is that a support crossbar I see below the engine, or something else?
SilverBullet75
Formerly: '01 Ebony VXSTLTH
Now: '08 Saab 9-7x Aero 6.0L
I think it is the tie down strap.
Tie down strap.
AutoPros of Aberdeen | AutoProsAberdeen.com
Follow us: facebook.com/AutoProsOfAberdeen
Driveshafts are done and the VX is back for us to do the A/C lines before heading to the exhaust shop. Pics to follow very shortly.
Working out small bugs and making the a/c lines today. This thing is a beast, and very responsive!
Little updates...
Refresh Head Light Lenses... DONE
Install HIDs... DONE
Speedometer & Tachometere Calibration... DONE
Refresh Exterior Plastics... DONE
Exhaust... SCHEDULED
AC Lines... ONE MADE, AWAITING ONE FITTING
Tires... ORDERED
Anyone else getting as excited as we are?
I can't wait to see detailed pics when this is completed!
While ya still got the old tires on there you need to put them to use...
.BURNOUT VIDEO!![]()
X2 on video
I have a question for the builder: On the first page of pictures you show one where you have ground away the corner of the steering gear in order to get clearance. Was there not enough to move the engine 1/4 inch to the passenger side.??? When you dropped the engine in and positioned it - did you spot weld the motor mounts then unbolt and lift the engine in order to do a more permanent mount of the mounts to the frame??? Just curious. Eb.
I've been wondering if a Jeep wrangler 4.0 I6 and transmission wouldn't be a decent fit. I know the HP is less but most VX's are probably running on the same HP more or less with worn out engines. ?? The 4.0 lasts forever and are easy to find.
