Results 1 to 13 of 13
Thread: Electrical Heat-Shrinkable Tubing
    Sep 2003
    '02 Jeep Grand Cherokee
    Question Electrical Heat-Shrinkable Tubing
    Question for you guys who deal with wiring. Does any of you use heat shrink tubing for electrical insulation? If yes, can you point me on where I can find detailed application technique (how to use/apply it!?)?
    Also, is an Electrical Liquid Tape can be one of the alternatives to the heat shrink tubing?
    Any thoughts would be deeply appreciated! Thanks in advance!
    Heat-shrink is the best stuff around. Liquid tape is fine, until you move the wiring later and it cracks. Heat-shrink is pretty simple, just remember to put it on the wire before you splice . A heat gun is the best to shrink it, but I use a pocket torch too. Just keep the flame about 4 or 5 inches from the tube so you don't melt it. Jameco is about the best price if you're buying in bulk. I work line repair for the Telco, so I know wiring. Heat shrink is your best solution.
    Stick with what works.
    Sep 2003
    Thank you hitnrun74!
    Do you know by the chance where I can easily buy it? What stores?
    Thanks again!
    2001 Proton VX 0790
    I'm using silicone tape, self vulcanising. it takes much more heat than shrinky tube.
    John C.
    Sep 2003
    Originally posted by Hotsauce
    I'm using silicone tape, self vulcanising. ....
    Thanks for your input Hotsauce!
    I thought about silicone tape as an alternative to heat-shrinkable too. Since both ends of my wires are already welded to devices I would probable consider silicon tape instead of heat-shrinkable tubes. Will ask my electrical engineer tomorrow at work to take a look at my setup …
    May 2002
    2000, Proton Yellow, VX, 0584
    The other alternative.. Do a google for PC mods.. There's lots of braided wire cover and shrink wrap available..
    BTW.. Why do you have a Jeep as your avatar?
    Scott / moncha.com
    2001, Proton Yellow, #0580
    If you only need a few pieces of shrink tube, you can buy the packs in various diameters at Home Depot in the electrical department. Only a couple of bucks and very accessible.
    -- John
    Sep 2003
    Originally posted by Moncha
    ... BTW.. Why do you have a Jeep as your avatar?
    Because I’m a guest here and I drive 2002 Jeep Grand Cherokee. One friend of mine is an active member of this respectful community and he drives VX.
    Thank you Moncha for your suggestion!
    May 2002
    Cool no harm meant.. Glad to have someone from another around. I like the PC sotes because you can get just about any color youcan imagine. Even UV reactive!
    May 2003
    2002CanalBlue5001
    Thumbs up Heat shrink is available at Radio Shack.
    I use heat shrink, you can also shrink it with a sodering iron.
    Speaking of solder, when I do stereo mod work, I like to drop some solder beads on the bare wire ends when connected and then shrink tube them. Your best bet for a strong and reliable connection. A tad bit of extra work, but very well worth it.
    here here ---solder is king
    Sep 2003
    Thumbs up Thank you so much!
    Thanks to all of you guys for your thoughts and suggestions!
    I appreciate your responses!
  1. heat not working
    Last Post: 10/16/2015, 01:22 PM
  2. help! no.heat
    By heavy d in forum VX Troubleshooting...
    Last Post: 08/28/2015, 07:20 PM
  3. no heat or cold heat
    Last Post: 11/04/2014, 06:49 AM
  4. no heat!
    Last Post: 09/02/2014, 10:16 PM
  5. engine heat
    By Triple X in forum VX Troubleshooting...
    Last Post: 03/03/2004, 03:53 PM
