im trying to find a current step by step for cleaning my egr valve - all the threads i found on here are outdated and say error 404 when i click on the links to the walkthroughs - any help is appreciated sorry i couldnt find it myself
 Super VXer
						Super VXer
 Super VXer
						Super VXer
						What makes you think it needs cleaning? I've owned three VX's, and travelled 150 K in them and never once cleaned the EGR valve or tube????????
 Super VXer
						Super VXer
						ive read on multiple threads on here that it could help in the elimination of oil consumption which i have slight bit of - im at 110,000 mi now and my engine is running like a top but i had a day off work was going to try some preventative maintenance - think i should just leave it alone?
Yep. Once you play with it, chances are, it will always give you issues. I am of that category. Replaced mine after my S/C install years ago, and now I encounter random issues with it. Imagine that....
In my opinion, the best thing a person can do to possibly alleviate excess oil usage in a VX is replace the PCV valve with a simple breather filter.
 Super VXer
						Super VXer
						How does this work? Will it pass inspection? What brand and part number do you use?
 Super VXer
						Super VXer
						so by eliminating the pcv you keep the oil vapor inside the crankcase instead of venting it into the intake manifold - which should lead to less oil burn but more sludge in the engine since that's the entire purpose of the system is to prevent oil contamination and sludge formation...but is the vapor able to actually vent through the filter? if it is venting properly and not allowing it to build up inside you would think the filter would need to be changed often because of all the oil vapor coming through it - it does makes sense that it would burn less but are you sure that is what is best for the engine? i guess it could be kind of a wash - on one hand you would burn less oil but need to change it more often because of sludge building up faster - where leaving it alone would burn more oil but should keep the system cleaner - not to mention that adding fresh oil when needed can extend the time in between changes a bit - im also assuming you would need to plug the vacuum hose for your vent to work? do you get cel from this?
 Super VXer
						Super VXer
						I've done it at least five times. I believe twice for a slow flow code, and other times just to keep the small tube clean. It's super easy. My gasket was always sealed to the valve, and I never replaced it yet. Others got a new gasket at NAPA for like $3, so have one on hand. A uni-joint will help with the bolts.
The process is the first question here-
http://www.isuzufaq.com/
If you have no trouble code to start with, you should have after running the engine with the valve off. Just clear it with a code reader.
I tried the breather thing for a short while years ago. I plugged the tube to the intake with a bolt and had a breather filter thing on the hole. It didn't reduce oil use for me at all, so I went back to the stock PCV valve.
It should not pass inspection with a breather like that, but it would be easy to change back just to pass.
Mark
 Super VXer
						Super VXer
						so the pcv is an environmental thing then like catalytic converters and the egr etc? sometimes i just wanna take all that s### off and see how it runs - have a check engine light but probably get 30+ mpg or something -heck i bet the oil companies where the ones who lobbied to get the epa to make that crap mandatory in the first place
 Super VXer
						Super VXer
						not throwing a code now and do not want to anytime soon if at all possible so i think i will probably just stick to using the stock pcv -i cleaned it out with carb cleaner it seems to be working just fine and looks in good shape - plus i dont use that much oil so its not that big of a deal yet - hey i dont have a code reader so do you have a suggestion of what type/brand/model might be decent/affordable and somewhat user friendly? - and fyi - in indiana we dont have inspections we just blow all out dirty air down to kentucky
 Super VXer
						Super VXer
						I think you're getting it now. You don't really need a code reader, just a ten mm wrench to remove the negative battery terminal for thirty minutes. Oh, and don't forget to reset the clock. If you need instructions on how to do that just holler.
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						Yes, the clock is part of the audio head.
