Results 1 to 5 of 5
Thread: wiring for front speakers(help!!!)
    Feb 2003
    1999, White, Ironman 0918
    how do I put through the wires from the new speakers in the front door to the amps? that rubber link that takes wires from the door inside the car is bent and I cant feed the speaker wire through, please help???/
    Ironman
    '99 Astral #1977
    Sorry didn't see this thread.
    I used the existing wiring in the front. You may want to try attaching the new wires to the stock wires and then pull the old wires through. Or try a fish tape. It is used just for such purposes running wiring in homes under carpet, through walls or whatever.
    RichD
    Oct 2003
    2000 Kaiser
    Fish it
    then Duck it
    two most used phrases in my shop, in jest of course
    Feb 2003
    I have resolved that problem. But I have now another problem. I hooked up the the sound system. I have a mini stereo out of the pc going into rca wires. they are going into the equalizer/crossover then I have 2 pairs of rca wires going into amps and then speakers.
    The problem is that the sound level coming from the pc and equalizer is very low. I tried playng with the switches on the amps and volume controlls in the computer, but that didnt help. I tried using extension from AC insted of the inverter for the computer and that didnt help. I tried running the wires straight from the the PC to the amps and that didnt help either ????
    People please in you have any ideas give me some help, because this project will kill me if id doesnt work.......
    Feb 2003
    2001, Black, VX, 0781
    Dude, once was enough, 3 times is getting annoying. If you wanted to make sure that everyone read it, you should have started a brand new thread instead of piggybacking it on every thread that might be relevant.
  1. Right side O2 Sensor wiring/TOD wiring harness proper locations
    Last Post: 07/27/2013, 11:32 AM
  2. Rear fog and front fog lights wiring
    By David Wiltshire in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/07/2013, 01:40 AM
  3. front speakers
    Last Post: 09/26/2012, 07:26 AM
  4. New speakers help please
    By BlackVX in forum VX Modifications...
    Last Post: 09/20/2010, 06:06 AM
  5. Help with wiring custom front signals
    By KILNA in forum VX Troubleshooting...
    Last Post: 07/06/2006, 09:38 AM
