Results 1 to 10 of 10
Thread: eaton m62
    2001,GREY,VX,0782
    eaton m62
    heard excessive rattling inside the supercharger, any idea if supercharger require rebuild, since I have a repairable kit, does anyone have a repair instruction can email me. Thanks
    Wink
    http://www.vehicross.info/forums/sho...harger+rebuild
    Use the search function, with "supercharger rebuild" as your criteria, for more info...
    2001, Proton Yellow, #0580
    If you reference that thread - I was never able to reach those guys to rebuild mine. It's still sitting in a box.
    -- John
    2001,GREY,VX,0782
    i got the rebuild kit, but cannot find instruction how to replace bearing and pulley kit, google all poss key words still cannot find anything.
    Wrench
    Quote Originally Posted by sean_grigoros View Post
    This was my "top of the list" goog result...using "eaton m62 + rebuild"...
    http://www.google.com/url?sa=t&rct=j...t3OspT-i6WTT7g
    It's not a factory pdf, but looks like it has some...OK, LOTS, of useful info.
    What's your goog technique ?
    2001,GREY,VX,0782
    i will try on Monday, I tried to replace the SC oil today, but still the same rattles, i really don't feel comfortable able that. don't want anything break on me while driving.
    2001,GREY,VX,0782
    the rattling seems coming from idler pulley bearing, I already push the bearing and will go match one up tomorrow.
    2001,GREY,VX,0782
    replaced idler pulley bearing yester, 80% noise gone, thank god. will monitor and post update for you guys, anyone know what belt should I order for the supercharger, all number on the belt is worn, need to match belt, I suspect belt worn causing premature bearing wear.
    Using "supercharger belt part #", i found this...Supercharger belt (6PK1225)
    Search function still works great...
