Results 16 to 30 of 31
Thread: Tyler's Mods
Threaded View
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    Tyler's Mods
    Never really posted anything like this. I'm always on the site getting the info I need to do what I want to do with the VX. I've been driving another vehicle AND separately working on my VX (here and there, not constantly) since Feb 2012 and I'm 98% finished (for real). I'll definitely be ready by Moab. I get soooo many emails and questions on how I did certain things, I thought I would just take the time and give back to this awesome family of ours... So I'm sharing the restoration experience of my VX with everyone here. This has definitely been a journey. I'm hoping that this thread may help others. I'm going to be a little vague in some of the tools and techniques used to keep things shorter however if anyone would like more feedback on something particular, no problem shoot me an email! I have documented so much information during this process, it's really ridiculous... but hey, maybe it will come in handy for someone at some point. I love this forum and I love to help anytime I can!
    Long story short...
    There was a lot of little things wrong with my VX. I also had accumilated tons of stuff that I wanted to install... so at some point I decided to fully restore the VX and add all the stuff to make it the truck I always wanted.
    NOTE: The original thread here was pointing to pics that I uploaded to my gallery. I have changed this so that there is less load on the server. Now, all of the pics are being pulled from my Photobucket account. Click on any image to enlarge. Although I participate throughout the site, I expect this particular thread to be long as this will serve as the single spot that I document each and everything I do to my personal VX. I also have a back up plan if Photobucket fails. I have this entire "story" also documented elsewhere in the exact same form and then backed up in a couple of different places, so if I have to duplicate it again (copy/paste) no problem. If any of the pics don't show up, msg me and I'll fix it. I don't have all my Photobucket pics posted, so if you want to see more pics (different angles of the same thing) then visit my Photobucket. Enjoy!
    Interior
    Remove Interior Components
    Seats, sub woofer box, sub amp, mid amp, all 4 mids including brackets, all 4 tweets including brackets, headliner w/sun visors & "oh sh*t" handles, all interior panels, carpet, all padding including floorboard area and firewall, seat belt assemblies, door-mounted mirrors, center console & related parts, rear tire holder and bracket and maybe more but I can't remember, but basically everything but the actual dash and dash components (which will be later)
    Clean Surfaces
    I used a Paint Scraper and good high end razor (w/plenty of replacement blades) to remove the rough stuff... such as removing the padding from the bottom of the carpet, removing the gluey stuff left behind. I could have just ripped and scrape everything out quickly, but I wanted to take my time as to not scratch patches of paint off since the layers of paint on the interior are THIN. I didn't want to be concerned about rust, so I took my time and removed everything...without damaging the interior paint. For removing the Acoustic Sealant (the black sticky stuff) that is used to fasten the plastic protector on the door panel and to fasten the carpet to the floor, I used (gently) the paint scraper to get the majority of it off, followed by Adhesive Remover made by DUCK (has an orange plastic scraper as the cap and is about $10 or so, much better than GooGone) works WONDERS on removing this stuff. Use the top of the bottle and insert it onto your thumb or a finger. Yes, it will hurt after a while of scraping, but you will NOT damage the paint this way as the top is plastic and doesn't scratch... and finally going over all metal surfaces with 91% rubbing alcohol to make sure the surface is ready for new adhesive.
    UPDATE: Looking back, since I was planning on installing Dynamat (which uses the same adhesive material) I would have done everything the same, except I should have just left the black adhesive "stuff" on the door. The backside of the Dynamat is the same black adhesive. There was really no point in removing it, guess I wasn't thinking and just got to crazy with it.
    While I'm at it, thought I would fix a few other things that were right there in front of me. Using CLR, clean and remove rust on:
    - the metal plate where the shifter is mounted in center console
    - the plate for the ABS Module under the passenger seat
    -any holes that have been drilled in the frame to mount amps, etc.
    Apply Dynamat Extreme
    Note: I actually paid a reputable car audio place to install dynamat on both my doors and I paid retail. Once I took the door panels off and saw what I actually paid for... I WAS PISSED! Look back at the first pics, under Remove Interior Components and look at the last 2 pics, this is the quantity of dynamat that they use if you pay for them to dynamat your doors. If you are going to pay someone to do this, make sure you review their work before it's paid for, but I HIGHLY recommend doing yourself. Clean everything up, lube the window tracks, make any adjustments for the window issue
    Using the MEGA Pack sized Dynamat sheets (24"x 48" per sheet) I covered the entire interior with Dynamat Extreme. I used as large of sheets as possible. Smaller "left-overs" were used for inconspicuous areas and to connect larger pieces. I kept most med to large pieces for future use. Ensured that all tension was relived in "troubled areas" by adding "tension slits" and to eliminate any air bubbles. I used the professional Dynamat Roller to finalize the install. I cut holes in any area where there is a pre-drilled hole and any areas where something will attach to the frame such as panel retainers (a must) and... important: make sure to cut out the area a bit larger than needed so you have room for the bolt head or plastic fastner to fit w/out touching the Dynamat. You want to be able to remove a panel in the future without ripping the Dynamat from the wall as you pull the panel off.
    Apply DynaLiner and DynaPad
    FLOOR - DynaPad (in center of floor, replaces OEM padding attached to carpet underside), 1/4" DynaLiner from under seats forward to the front fire wall including center console area, 1/8" for trimming around edges and tight areas.
    ROOF - 1/2" DynaLiner in the deep pockets of the roof (where Isuzu had original roof padding installed). Some areas used 1/4" DynaLiner while the remaining areas used 1/8" DynaLiner to ensure complete coverage
    Ty
  1. mods mods mods on the mind.
    By ABDragonVX in forum VX Modifications...
    Last Post: 03/09/2013, 08:51 PM
  2. Mods, Mods, Moab, Mods
    By ND92 in forum VX Modifications...
    Last Post: 05/08/2012, 07:35 AM
  3. First VX mods =]
    By Breezy in forum VX Modifications...
    Last Post: 08/06/2011, 05:39 PM
  4. Little mods of my JDM ;-)
    By CIAUS in forum VX Modifications...
    Last Post: 10/28/2009, 12:18 PM
  5. Tyler's Window Problem
    Last Post: 05/20/2007, 12:11 PM
