Quote Originally Posted by Daly View Post
I will go into have it diangnosed.
What is MAF?
Where is Idle air control valve located? Easy replace?
It probably is not an EZ fix. JK do a search on MAF Mass Air Flow or Idle air control valve both have better directions in the how to than you are likely to get here and judge based on you ability. It may be something as simple as a cut in your air hoses letting too mauch air to gas mixture.
