Results 1 to 14 of 14
Thread: engine light
    Get your CEL code (Advance/AutoZone will scan it for free) and that will help the diagnosis a lot.
    Jan 2012
    2001, Ebony Black, VX
    Mine did that same thing, but I never had a CEL come on. I had to clean out or replace the Idle Air Control Valve (IAC). Maybe your MAF? The CEL code would be really helpful!
    '03 Honda CR-V (DD) - '05 Jeep Wrangler Rubicon - '01 Ebony VX!
    A smile is like tight underwear, it makes your cheeks go up!
    Jan 2010
    2001 black 1145
    I will go into have it diangnosed.
    What is MAF?
    Where is Idle air control valve located? Easy replace?
    Jun 2007
    2001, Proton
    If you have to ask
    Quote Originally Posted by Daly View Post
    What is MAF?
    It probably is not an EZ fix. JK do a search on MAF Mass Air Flow or Idle air control valve both have better directions in the how to than you are likely to get here and judge based on you ability. It may be something as simple as a cut in your air hoses letting too mauch air to gas mixture.
    Carter Pewterschmidt
  1. Help!!! My Check Engine Light Is On!!!
    By littlewing2 in forum VX Troubleshooting...
    Last Post: 03/15/2008, 11:13 AM
  2. Check Engine Light
    By Bucky7 in forum VX Troubleshooting...
    Last Post: 06/06/2006, 10:13 AM
  3. K&N = Engine Check Light?
    By JAFO in forum VX Troubleshooting...
    Last Post: 02/16/2006, 09:52 PM
  4. engine light on, tod light on
    By sean_grigoros in forum VX Troubleshooting...
    Last Post: 10/05/2005, 07:56 PM
  5. Check Engine Light...
