Results 1 to 11 of 11
Thread: Question on Timing Belt Change Issue - Bart?
    Jul 2004
    2000, Kaiser Silver, 0196
    Just do it. Given the old belt was intact and everything was lined up before you loosened the tensioner, if you have NOT rotated the crankshaft or cam pulleys after you removed the belt all you have to do is pull them back to the marks, clip them, line up the marks on the crank and pull the pin on the tensioner. The relationship between cams and crank will be maintained and you'll be good to go. This horse has been flogged a few times (sorry!) but bottom line is the engine is happy whether you line it up per Isuzu's instructions or per Bart's intructions.
    It would still be prudent, however, to do as the manual says and rotate the engine by hand a couple revolutions to make sure there's no interference before you put the spark plugs back in and fire it up. Better safe than sorry!
    2000, Ebony, VX, 0370
    Thanked: 12
    When I did my timing belt change, per Bart's instructions, I seem to remember one of my cams sprang to the 12 o'clock position, but the other jumped to the 3 o'clock position. I think it all depends on how the valves are pushing on the cam at the time you release the tensioner.
    Like SlowPro said, as long as everything was lined up when you took the tensioner off, and you haven't rotated anything, then when you line everything back up it should all work out just fine. DO rotate the motor by hand a few times to make sure that everything is happy before you turn the key.
  1. Waterpump and timing belt change
    By KRemo in forum Chit-Chat ...
    Last Post: 04/01/2015, 07:00 PM
  2. Timing Belt Change Question
    Last Post: 02/08/2014, 06:08 PM
  3. Shop price for timing belt change.
    By fun173 in forum VX Talk...
    Last Post: 04/01/2013, 11:09 PM
  4. Change Timing Belt & Water Pump In 15 Seconds
    By jasonm621 in forum VX Talk...
    Last Post: 01/20/2013, 08:20 AM
  5. Timing Belt Change
    By DeepSilentComplete in forum VX Talk...
    Last Post: 06/22/2009, 06:35 AM
