SO, this weekend, I pushed out to the desert from sea level to 4K feet with about 800 lbs of guns and freinds in the VX. 100 miles each way. About an hour in, during the steepest part, I am running hot, but not overheating, about 220. I have made this drive many times before. Then the A/T oil temp light comes on. I top the hills, and drive easy the rest of the way and the light goes off after about 5 miles (I opened the windows and threw the heater on too to pull a little more heat). I pull in and I have a dripping leak on the top of the radiator that seams to stop when it cools down, I finish our adventure and on the way back, i stop to check again. The radiator is dripping again so as I am in the middle of nowhere i put in the standard Bars stop leak. That does the trick. I get home no problem and have done short trips with no issue.
Here is my plan:
Drain the trans and replace trans fluid.
Flush and refill coolant.
Oil change
Any other ideas or thoughts? This is an aftermarket radiator that i replaced about 6 years ago.
