Results 1 to 11 of 11
Thread: Cross member fit issues..AFTER diff drop...HELP!
    Just FYI...
    Having chatted with Dub and looked at the cross member again...
    ....I do believe I am going to cut Toms "H" brackets down leaving
    a 1/2 - 3/4 inch "stub" where he had the bolt holes for the c/member
    on the lower legs of the "H"
    It will essentially leave a saddle bracket with stubs.
    I will weld the Calmini c/member to these stubs ( extra surface area)..
    ...and that will secure it solidly, AND tuck it up a bit higher for clearance.
    It will still be removable with 4 bolts as before.
    Any comments and / or derision ( ) glady accepted!
    I've got a set of CM drop brackets that were designed for the Calmini CM. If you like, I can get them in the mail today.
  1. Have you installed a diff drop?
    By Marlin in forum Polls
    Last Post: 10/11/2014, 10:51 AM
  2. Diff Drop Brackets
    By UWVX89 in forum VX Modifications...
    Last Post: 11/18/2012, 12:06 PM
  3. diff drop
    Last Post: 08/23/2012, 12:31 PM
  4. Diff Drop Brackets
    By ZEUS in forum VX Modifications...
    Last Post: 07/29/2008, 10:18 AM
  5. My diff drop.
    Last Post: 04/03/2008, 09:30 PM
