Results 1 to 9 of 9
Thread: P. Side window motor
    Nov 2011
    1999 Silver VX #0758
    So I ordered a reman window motor off ebay and to my suprise it does not fit.
    I knew it was to good to be true. As long as I had it out I tore it apart. I did get it to work again but the gears are worn out. So any idea of where I can get one.
    • See if VX Crazy (Lisa) or etfren (Eric) have one , as both are parting out a VX.
    • Use "mypartshop.com" or "car-part.com", both search a ton of salvage yards across the country.
    Nov 2011
    Thanks for the info. Not sure if I want to spend the $$ for new.
    Aug 2010
    01 Foxfire Red Mica VX 0441
    If I'm reading right, a new regulator is not bad @ $95.
    2001 VX
    Mods
    2008 HUMMER H3
    Nov 2011
    Thanks H3, but it is the motor. The gear has a spot with stripped teeth. Merlin's web site has one for $213.00. I have been busy and did not check into a used one yet. Not sure if I want to go that route yet either. The parts store that sold me the wrong motor said I should be able to send it in and have it rebuilt for around $70.
    Dec 2010
    2001 Proton Yellow VX 1268
    If its just the motor I bet the rear door on a trooper would be the same one. I was working on my dads trooper (a 2001) a wile back and it used the remote motor type like the VX's I would check out the junk yards, lots of troopers there. As I recall the whole regulator looked very similar it just might fit.
    Twostep (Phil)
    Jan 2011
    2k, White, Ironman, 0031
    Hi. you can get it at Rockauto for about $60.00 plus core deposit. http://www.rockauto.com/catalog/raframecatalog.phpore. It is under body interior.
    Nov 2011
    Quote Originally Posted by Skydoo View Post
    Thanks but the one I had was the A-1 Cardone 474309 and that is the wrong one. A-1 has it wrong in their catalog. They do have another one listed I will check out.
    Looks like #474321 is the correct one for the VX.
    Nov 2011
    Quote Originally Posted by twostep1n2 View Post
    I think the trooper motor is smaller as it has a smaller window but I could be wrong.
    Thanks for the reply though.
    I am working with the place that sent me the wrong one to see if they can get me A-1 Cardone #474321. That looks like the correct one but not sure if they have any in stock?
  1. Burnt out window motor
    By David Wiltshire in forum VX Troubleshooting...
    Last Post: 05/03/2014, 02:39 PM
  2. Window Motor or Switch?
    By jmassa in forum VX Troubleshooting...
    Last Post: 11/07/2011, 07:03 PM
  3. Window Motor
    By Joe Izusu in forum General Tips...
    Last Post: 01/12/2009, 06:53 PM
  4. Window Motor price???....
    By Thejerseyfish in forum VX Troubleshooting...
    Last Post: 01/23/2006, 12:32 PM
  5. Window Motor....
    Last Post: 01/14/2006, 12:59 PM
